AMG 19" 5 spoke OEM - widest tires?
What are the widest tires (PS4) that I can mount without any additional adapters or anything.
I have the same stock wheels as well and planning to buy PS4S tires, and also up the sizes a little
They are currently:
Front: 245/35R/19
Rear: 265/35R/19
So I can go 285/35R/19 rear and 255/35R/19 front without any problems and correct fitment?
Would 275/35R/19 rear with same 245/35R/19 front maybe be better setup?
I already changed the fronts to this size.
I will change the rear's as well once they're more worn.
With the sizes you are talking about, 35 is the way to go.
With a 9 1/2 inch rim the widest Acceptable tire is a 285 and the preferred is a 275.
Just rubbing is not the whole reason to choose a size. The shoulder of the tire is not supported enough if you go wider and the face of the tire is not in full contact. The latest Corvette just added a 1/2 in wider rim to its tire with the same size tire as they say it did not support the shoulder enough. Also the 30 aspect tire is smaller and won't fill the wheel well . It was said it is not much smaller but if you go larger with a 35 it is larger than the stock. a 295 /30 is 26.0 inches and a 285/35 is 26.9 so you get a better ride and .9 in. larger tire to fill well.The ride is some what better and I think it is too firm now and I would not want worse.
