Does anyone even use Sport mode?
Does anyone even use Sport mode in your C63 and why?
God i wish there was a way to reprogram it to Sport+ that is starting from 2 (like Comfort).. my only problem with Sport+ not wanting the first shift in city.
I should add that my personal "I" is set for engine = S, suspension = S+. and exhaust = S+. I just prefer the shift points on the S setting for normal driving.
a. it's throttle setting which is my default setting in individual mode. I really like being able to control the throttle response vs how comfort mode does it ( i think i can offer a smoother ride by modulating the pedal in sport mode than in comfort mode which is too mushy and then kicks in too much.
b. the suspension - not sure what is up with the suspension in comfort mode but at higher speeds, the suspension is quite springy, and i need to push the suspension button to stick it in sport, or sometimes sport plus to give me less roll. I have an estate and it is a bit bouncy when going on country roads at higher speeds
c. The only time by default i stick it in sport mode is at night in urban areas where i want to drive fast but without the exhaust set to max bellow. The stiffer springs give me a more planted car and the exhaust button set at off doesnt wake up all the snoozing folks close by
On longer highway drives or traffic, I stick it in comfort mode (with auto stop/start disabled).
Rarely, I use Sport suspension on certain roads when it’s too floaty (Comfort) or too stiff (Sport+). But never actually use the Sport mode setting.
Sport mode would be perfect for me if:
- It started in 2nd gear like Comfort mode
- Had the same crackles and bangs as Sport+
- Suspension was in Comfort
- Exhaust on loud
Maybe some day a tuner will be able to do this (or other combinations) for C63's
After that if just cruising around town I flip back and forth between "Sport" and "Sport +" because I find "Sport" shifts more the way I like for normal street driving and since my AMG has Weistec cat less DP's...in Sport mode it just gives my car this deep throaty German Muscle sound
Being that my car is an "S" I do use "Race mode" when running in 1/2 mile events and the occasional street challenge...LOL
- Comfort + Exhaust-flaps-open (mapped to AMG Drive Unit left-hand-side button 1) + Auto-start-off (mapped to AMG Drive Unit left-hand-side button 2)
- Individual - Sport+ w/Suspension in Comfort - mapped to AMG Drive Unit right-hand side button on the Dial.
I stick with Comfort after I do a cold-start, and I switch to Individual only after the engine/tranny temps are in the white mark.
I also switch to Manual Transmission mode using the button on the console while driving on non-highways, again only after the temps are in the white mark. I have tried other suspension settings but I have found them pretty stiff unless I'm on a race track or something.
- Comfort for residential driving, commuting to work (usually with Distronic semi-autonomous on), crappy weather, or if the engine is cold.
- Individual (set to mostly Sport+ but with Comfort suspensions) I use 90% of the time for everyday driving.
- Sport+ for spirited driving on weekends.
What I like about Sport mode is:
- It takes off in 1st gear smoothly without being brash or jerky.
- Excellent for drag racing from a standstill.
- Comfortable even with the suspension is on Sport setting.
- No obnoxious pops and bangs. Especially after living with the secondary cat delete for the last 6 months, the backfires can get tiresome after a while.
- It double de-clutches on downshifts.
- You can use it comfortably in traffic as it won't downshift into 1st gear until you slow down to 2km/h.
How about you lot? Who else uses this mode?
Anyone here actually like to drive with the exhaust on quiet sometimes, too?
... I dont understand the use case/scenario for it.
