[Help Appreciated]Front Grill Badge Removal?
Subscribe
Oct 13, 2018 | 01:36 AM
Hi fam,
Does anyone of you ever tried to remove the front grill "AMG" badge (pic attached)? Would be great if you can kindly provide some insights on how to remove them. Do you have to remove your front bumper to remove it? What tools do you need?
Thanks!!
Reply 0
Oct 13, 2018 | 12:33 PM
I removed and exchanged mine without removing the bumper, but I had some pretty specialized tools (cheap, but unlikely you have the same ones).
It's held in by 2 small torx screws... You'll just need a short enough driver to fit into that space (like the ones found on eyeglass repair kits).
Reply 0
Oct 13, 2018 | 01:14 PM
Quote: I removed and exchanged mine without removing the bumper, but I had some pretty specialized tools (cheap, but unlikely you have the same ones).
Is it possible to kindly share the links of the tools that you used? Also, do you just need to work on it from the outside (just pull it out??), or you will need to reach from the inside with hood open?
Reply 0
Oct 13, 2018 | 01:19 PM
Unfortunately I don't have a link to it as I've had these tools for over 10 years haha... I just found something that worked. Look for a torx screwdriver set made for glasses or cell phones.
You pop the hood and do all the work from behind the grill... There is enough room to squeeze your arm and hand behind the badge. Once you undo both screws, the emblem just falls off. Just make sure you don't drop the screws from behind, otherwise you might actually have to remove the front bumper haha.
Reply 0
Oct 13, 2018 | 02:14 PM
Screwdriver Set, S2 Steel 60 in 1 with 56 Screwdriver Bits, Precision Magnetic Driver Kit, Professional Repair Tool Kit for iPhone, Computer, PC, Glasses, Laptop, Camera, Other Electronics Devices https://www.amazon.com/dp/B0733B73SV/ref=cm_sw_r_cp_apa_3wJWBbCW3Q30B
That would work perfectly
Reply 0
Oct 13, 2018 | 04:29 PM
I’d like to know how the small grille sections comes off so I can wrap it black.
Reply 0
Oct 13, 2018 | 04:35 PM
You need to remove the bumper to get that piece out.
Reply 0
Oct 13, 2018 | 04:42 PM
Quote: You need to remove the bumper to get that piece out.
well I’ll looks like I’ll wrap it while attached lol
Reply 0
Explore
Oct 13, 2018 | 06:53 PM
Quote: well I’ll looks like I’ll wrap it while attached lol
Yup, that's how most people are doing it.
Reply 0
Subscribe
Currently Active Users (1)
