ASR Exhaust Module
As a general rule of thumb, mods that works on S models applies for non-S models as there is really negligible difference between the two.
I guess I will post the sound clip vids here as well. Somehow I ended up on a C43 thread asking questions when I was looking into this. The vid is posted there as well, not sure if it's a no-no to post the same link twice on the forum. Anyway, the first clip is cold start with ASR module activated, second clip is stock cold start, third clip is running stock and then activating the ASR module. Enjoy!
I've just upgraded to a 2019 and have an ASR module plus a set of AWE valve simulators for sale in the UK. I'm looking for £200 for the ASR module (shipping extra depending where you are) and £40 for the valve simulators (shipping also extra) - hopefully nobody minds me posting this here!
Supongo que también publicaré los videos del clip de sonido aquí. De alguna manera terminé en un hilo C43 haciendo preguntas cuando estaba investigando esto. El video también se publica allí, no estoy seguro de si es un no-no publicar el mismo enlace dos veces en el foro. De todos modos, el primer clip es de arranque en frío con el módulo ASR activado, el segundo clip es de arranque en frío en stock, el tercer clip está en stock y luego activa el módulo ASR. Disfrutar! [/ Quote]
Well, if there is a difference, I like what I hear! one thing . I also want to buy the module but I have seen that it has two versions, one of facelift that is installed in the boot and another normal one that is installed under the steering wheel if I understand correctly. which one should i buy? my car is from 2017. thanks
