C63/C63S AMG
BMS 2018 C63 JB4 Dragy Testing
Old Nov 19, 2018 | 12:55 AM
BMS's Avatar
BMS
Former Vendor of MBWorld
2018 C63 Sedan
Hey guys,
Was great boost weather tonight (55F) so decided to head over to the private track for a few pulls.
Testing was done in our 2018 C63 base model, JB4, BMS intake, 30% E85 fuel. JB4 tuning was set to map5 (+7psi over stock peak), launch mode active, and to improve traction I used the JB4's boost by gear option to reduce boost by 4psi in 1st.
Overall happy with the best run of 11.5@127mph. If we could get that 60' down in the 1.7s range where it should be, look out!
Old Nov 19, 2018 | 01:30 AM
ezatnova's Avatar
2016 C63S
Thanks for posting those.
1) is it fair to say that the 30% E85 you are using makes the CA limited 91 octane perform like 93 octane? Or, if it effectively better than straight 93?
2) I see you used launch control, but was traction control left along (ie in sport or sport + and leaving ESC alone), or was it in the slippier mode that it uses when in Race or the ESC is pressed once?
Old Nov 19, 2018 | 11:36 AM
BMS's Avatar
BMS
2018 C63 Sedan
E30 based on 91 is probably a little better than 93 octane, maybe 94-95 octane. Like 93 with a can of octane booster for example.
Traction control fully off (hold button for 5 seconds), not sure if launch mode will engage otherwise?
Old Nov 19, 2018 | 12:26 PM
ezatnova's Avatar
2016 C63S
Yes, launch mode engages. It is actually faster in most cases on the street with normal tires to leave it in Sport + and then do launch mode. It allows a little slip but doesn’t make you modulate throttle to actually get going.
Anyway, is there a strong reason for testing on a non-pump gas setup, when probably 95+% of your customers will simply be running 93 or 91? Hopefully the bulk of the R&D/tuning is around that.
Old Nov 19, 2018 | 03:12 PM
BMS's Avatar
BMS
2018 C63 Sedan
Being able to mix in E85 fuel when wanted is what separates the JB4 from many of the other C63 systems currently out, so it's a large focus of our development. And certainly what map5 is intended for. I think we have a lot more room to improve power on E85 mixtures too.
There are also 91 octane and 93 octane maps enabled that can be selected on the fly using the smart phone app. In terms of their perforamnce we'll have to see. I'm not holding out much hope for 91 octane, it's really poor fuel and often requires detuning. But 93 should be able to produce similar results. Also note we have a non-S model. We'll have to evaluate how those respond as well.
Old Nov 19, 2018 | 03:17 PM
notabenex's Avatar
C63 W205 17' + W205 C250@brabus + NSX 95'
What if we are using here in EU 99/100octane gas?
Old Nov 19, 2018 | 04:12 PM
V8rumble's Avatar
C63
how have you got launch mode in a non S?
Old Nov 19, 2018 | 04:13 PM
KJ's Avatar
KJ
2020 GLE 53 AMG
EU rating and North American gas ratings aren't the same.
EU uses RON (Research Octane Number)
NA uses AKI = [RON + MON (Motor Octane Number)] / 2
MON is approximately 8-12 points lower than RON.
Since you're taking the average, the EU rating should be reduced by 4-6 points to get the North American AKI equivalent.
That brings your rating down to around 93 octane equivalent in North America. In Canada, we have 93/94 Octane readily available.
Old Nov 19, 2018 | 04:20 PM
ezatnova's Avatar
2016 C63S
it’s really weird, some of them have it! I didn’t believe it either but there are some pictures and video of people who have non s and have it. And then a lot who don’t. So many versions of softwares out there.
Old Nov 19, 2018 | 05:38 PM
BMS's Avatar
BMS
2018 C63 Sedan
That Arial 99 German fuel is like race gas compared to the 91/93 octane RM2 fuel used here. So you'll have no issues running the highest boost maps.
Old Nov 19, 2018 | 05:40 PM
BMS's Avatar
BMS
2018 C63 Sedan
I think everyone has it? Works just like the video. Sport mode, traction control off, press brake pull both paddles, pull right right paddle to confirm, floor car, let foot off brake. Of course traction is an issue so that is where the JB4 comes in to play, you can dial back boost in 1st gear for a faster take off. Even below stock boost levels if you needed. You can see it in action in the JB4 log I posted.
Old Nov 19, 2018 | 07:53 PM
silverstar11909's Avatar
c class
Well yes I think we all know that traction is killing us
anyway you guys can run the test with a wider rear tire...
i think there is member running that time with eurocharged...
really want to see that tire plus adjustable boost for the lower gears and see what this car can do...
thank you
Old Nov 19, 2018 | 10:21 PM
skim7x's Avatar
Mercedes-Benz E63s AMG
Oh... I have a non-S and it has launch control... I thought they all did...
Old Nov 20, 2018 | 06:40 AM
V8rumble's Avatar
C63
I thought only the S had launch control with the Race setting so I’ve never bothered trying it on mine!
I will give it a go and report back
Old Nov 20, 2018 | 06:41 AM
V8rumble's Avatar
C63
Do you have the 100-200 time please?
Old Nov 20, 2018 | 07:40 AM
skim7x's Avatar
Well then, Merry Christmas to you Sir. 😂 Just no Race mode, only S+, but you do have Launch Control... And all the C63s guys use S+ mode anyways haha
Old Nov 20, 2018 | 09:15 AM
V8rumble's Avatar
C63
Where’s the like button?! 😂
Old Nov 20, 2018 | 01:13 PM
BMS's Avatar
BMS
2018 C63 Sedan
No, app doesn't reocrd it currently. Sorry! 60-130 was just OK, could be better if it was a dedicated 60-130 run. Will try one later.
Old Nov 20, 2018 | 01:17 PM
V8rumble's Avatar
C63
It does change the settings
Old Nov 20, 2018 | 01:23 PM
EkS's Avatar
EkS
C63
You're using km/h BMS is using mph.
Old Nov 20, 2018 | 01:26 PM
V8rumble's Avatar
C63
yes I want to know what it did in kmh
Old Nov 20, 2018 | 03:38 PM
AlexZTuned's Avatar
2017 Porsche 911 C4
He's saying they can't run in both KPH and MPH. If you want to get a 100-200 KPH time, BMS needs to create a custom mode in Dragy set as 62 MPH - 124 MPH.
Old Nov 20, 2018 | 03:44 PM
ezatnova's Avatar
2016 C63S
Or they could just set the toggle in settings to metric. I'm sure it would benefit all of their ex-North American customers to see a set of runs in KPH
Old Nov 20, 2018 | 05:45 PM
AV1's Avatar
AV1
C204 C250-CDI
AFAIK there are only 3 Countries in the World still stuck with entirely using the old imperial units system lol I'm sure it's possible to have a setting to default to metric for everybody else
Old Nov 20, 2018 | 05:58 PM
Fame Douglas's Avatar
2018 C63 Coupe
So what are you saying, here? Because it sounds like you don’t recommend running 91octane with the JB4. can you clarify, please?
