Wider Wheels and Tyres C63 W205
Many thanks
Mr T
I can can confirm the below specs will fit C63S Sedan that is lowered 20mm f&r and fitted with K-Mac f&r camber kits with 1.5 neg camber front and -1 neg camber rear.
Front: 265/35/19 PS4S / 19x9.5 et 30
Rear: 295/30/19 PS4S / 19x10.5 et 57
Hope this helps.
Whats grip like with wider tyres?
I'm desperate for more grip.
my car has standard suspension so I wonder if it will work with your wheel offsets?
Hope this helps.
The car feels & handles a lot tighter now with the wider wheels.
Now that I’m fitting the Yabeela turbos I’m picking some Toyo R888’s up this weekend for the rear.
If these better the traction over the PS4S’s i’ll buy a full set of the R888R’s.
I am tossing up if I should increase the 265 to 275 up front or if I should just fit a 10mm spacer.
I dont have any rubbing up front with the 265’s so I’m worried about increasing width and maybe scrubbing the guards.
Your standard suspension will be fine.
if I remember correctly you had 295 on standard wheels?
who do you recommend going through for a reasonable price on wheels ?
hot weather solves most of the traction issues on the saloon version for free...
Regards,
Mr cheapskate AMG owner
295/30/20’s would have increased the rolling diameter by an inch which I believe would have scrubbed inner and outer guards.
I couldn’t get my hands on this size tyre to physically trial the fitment so with all these factors I just cut it away and stayed with the combination I knew would work.
Theres a thread here somewhere that I posted if you want to check it out, just can’t remember the title.
I appreciate your advice
I’m going for a similar set up to you. BC forged wheels
same offsets as you. I need maximum grip as my car has 400kw atw with current tune.
sticking to 265 up front. I don’t want go any wider up front as I think it will impact steering feedback and turnin.
My car is White and I currently have the black wheels. I really like the clear brushed look but am scared of how hard it will be to keep them clean.
What tune & mods are you running to achieve 400kw atw?
Id be interested in seeing the clear brushed look and you can always ceramic coat them to ease the cleaning process.
https://unichip.com.au/suitable-for-...s-2015-present
if you get a chance is there someway of working out how much of a gap you have on the inside of your rear wheels?
im wondering if I can get an offset slightly more in that will allow for me fit 305’s
Apparently no no stock left anywhere in the country.
I may need a backup plan if my tyre shop can’t get the tyres?
Tyre shop recomemded the Yokohama ADO8R. Anyone tried them?
