Weistec Coilovers Suspension for 2017 C63s Coupe
I’ve been feeling the ride quality of my 2017 C63S Coupe is too firm and uncomfy. I’m wondering if anyone here has installed Weistec that could share the experience? Does it improve the ride a lot? Does the OEM adaptive suspension system still work when changing between comfort, sport, sport +, individual, and race mode? Any input will be appreciated! Thanks in advance guys!
https://www.google.com/search?source....8.8WAShiw7eTA
https://mbworld.org/forums/c63-c63s-...63s-sedan.html
I'm also researching the best option for lowering one of these with either springs or a HAS type kit, few questions about the Weistec HAS - is that small drop you have there the minimum drop of this kit ? ie. does it start from same as stock OEM height and go dowm from there or is 12mm you have the starting drop height ?
I ask this because at least 2 other HAS kit brands start at or over 20mm drop as minimum so you can't maintain as close to OEM is that above.
TIA
Not really keen on the KW HAS just from too many negative reviews of it re. noise issues, also that is one of the lowering options which starts with a low drop as minimum, so if you only want a slight drop as you've done it won't do.
However I'm still looking into a HAS type kit because I'm acquiring several different sets of aftermarket wheels and they'll be of different sizes (diameter) for different purposes, so having that flexibility of height adjustment is advantageous in my case.
It seems like it'll be a choice of either the Weistec - which has also been recommended to me by a local tuning shop who's fitted several to 205 C63's without issues or the Bilstein HAS kit which I still need more info on.
