C63/C63S AMG
2017 c63 amg limp mode
Old Jun 30, 2019 | 12:53 AM
46m3csl's Avatar
2017 c63
Cant use the manual pedals and the power is wage down
Old Jun 30, 2019 | 10:12 AM
FLC63s's Avatar
AMG C63s Sedan , AMG C43 , AMG G63 , GLK 250
Gonna need a bit more info then that .....
Old Jun 30, 2019 | 11:48 AM
46m3csl's Avatar
2017 c63
Scanned with ob2 turns out it throw fault code for p2743
Old Jun 30, 2019 | 12:30 PM
gOt BoOsT's Avatar
‘17 GT F1A E85 Monster ‘16 C63s
That’s for trans temp too high so either the sensor is bad or you have a leaking heat exchanger causing high trans temps
Old Jun 30, 2019 | 12:31 PM
FLC63s's Avatar
Well that code is for transmission sensor (temp) and would definitely put your car in limp.
You need to get it check if its a faulty sensor or something going on in tranny.
but 1000% i wouldnt be driving it , more so hard
just my .02
Old Jun 30, 2019 | 12:38 PM
46m3csl's Avatar
2017 c63
just my .02
What should the transmission temperature be at after a hard drive ? Current cruising temp was at 240
Old Jun 30, 2019 | 12:48 PM
FLC63s's Avatar
Why are you opening more threads for each question ??
Your Oil TEMP is WAY HIGH...
Limp mode is engineered for a reason, when the systems signal that something is happening that could cause damage to the engine/tranmission etc, it puts in limp so , you can get to a safe stopping point etc..
(not drive around and see if it goes away)
Old Jun 30, 2019 | 12:52 PM
46m3csl's Avatar
2017 c63
It's a stored code , after restarting it everything went back to normal. Just trying to figure out where the trans temp for this thing should sit at.
Old Jun 30, 2019 | 01:42 PM
FLC63s's Avatar
From what I have read and heard from people , normal and under hard driving, upto 200 f is what has been seen, even on hot days. (if your tracking it and behind other cars etc, and getting all that exhaust heat , it could go up.
The manual says @248 degrees (f) would be the limit.
Old Jun 30, 2019 | 01:49 PM
msd3075's Avatar
'15 C63S
If your car went into limp mode even once, you need to have the car looked at to see what caused it. If it was that the transmission oil temps were measuring too high (240 is way, way too high), you need to have the dealer investigate why that's happening.
Simply because the car reset itself out of limp mode after a restart doesn't fix what caused it to go into limp mode in the first place.
Old Jul 2, 2019 | 11:44 AM
velosdesignwerks's Avatar
Former Vendor of MBWorld
Mercedes C63S AMG (W205)
Im in Miami FL, its very hot and humid here. Make sure you are taking conditions into account.
Normal Driving Oil Temp ~ 200-204F
Normal Driving Trans Temp ~ 195-198F
Hard Driving Oil Temp ~210-218F
Hard Driving Trans Temp ~197-201F
But based on my Temps your are absolutely too high.
Old Jul 2, 2019 | 12:36 PM
Spectre-13's Avatar
2019 C63 S Selenite Magno Grey
Also, it might be a good idea to have the transmission fluid replaced after being subjected to high temps.
Old Jul 2, 2019 | 12:46 PM
DRGG's Avatar
C63S AMG Coupe
2018 C63S here. I had a problem with high trans oil temps (went up to 259 deg), and never experienced the car going into limp mode and no fault codes Thankfully I always have the AMG display on so I can always see the boost and temps and caught it early. Turned out to be a leaking aux. charge cooler.
Old Jul 3, 2019 | 07:35 PM
46m3csl's Avatar
2017 c63
So I did have a fault code store in the system which I scanned before taking it to the dealer which was p2743
Here is what the service advisor is saying
"hi there, it appears as though the cooling system has been drained or opened up at one point. we will need to drain & refill the charge air cooling system In addition to bleeding it. it's not something i can cover under warranty & will be $225.00 + tax to do"
Is this a load of bs , because how can they tell if the system was opened or not .
Old Jul 3, 2019 | 07:50 PM
msd3075's Avatar
'15 C63S
You can easily tell if that cooling circuit is dry. Just look at the reservoir in the top/front of the engine near the turbos. There should be pink coolant visible in it. If not, you have a leak. And the leak more than likely is from a rock hitting the radiator. If so, it'll be another $1K-ish to replace the radiator.
Old Jul 3, 2019 | 07:52 PM
46m3csl's Avatar
2017 c63
Never had a low coolant warning or any leaks on the ground after driving the car.
Old Jul 3, 2019 | 07:55 PM
msd3075's Avatar
'15 C63S
There is no low coolant warning sensor on that cooling circuit. Your only warning is the trans temp reading on the AMG screen or an eventual CEL.
I had it happen to me, and the circuit was dry before the next time I stopped after the rock hit the radiator. But there should be coolant all over the undercarriage. Pretty hard to miss.
Old Jul 3, 2019 | 08:01 PM
46m3csl's Avatar
2017 c63
Yeah not a single drop on the undercarriage
we cannot find anything other than air possibly being in the system, there is evidence that the system has been opened up which is why we will have to start there
Lol dealers response, clearly a guess game even though the car had a fault code stored in it . This is ridiculous
Old Jul 3, 2019 | 08:03 PM
msd3075's Avatar
'15 C63S
Unless you are able to pull the undercarriage off and look at the top side of it, you won't be able to see it.
Old Jul 3, 2019 | 08:19 PM
46m3csl's Avatar
2017 c63
Text STOP to opt-out.
--Mike Doehla Mercedes-Benz of Ontario
Fail dealership
