Spark Plug change ...
also FWIW, talking to several of the best tuners, including Renntech, their consensus is that there is absolutely no need to change from OEM gap on the plugs. Renntech has had their R3 C63s running well over 700hp and only ever had stock gap plugs in it.
Now, if the JB4 caused extra stress on the coils due to the plugs struggling, then that may be a separate issue, but hopefully that isn’t the case.
FWIW, another reputable tuner mentioned to me that, while stock gap is perfectly good to use, a tuned W205 should have plus replaced every 15-20k. That’s just one data source though.
Occasional misfires at idle. Take out your plugs and look at them. Stock you can get away with it, tuned stage 2+ I'll do mine every 20K miles and IDGAF what MB says.
I'm probably going to have to get them from the dealer if I want them done by next week, which is the plan, but what is the ngk equivalent part number? I might see what is available locally. Also does anyone know torque spec on the plugs?
