Navigation Update
A new version for your navigation maps is available at the Mercedes me Portal.
You can download the maps from the portal to bring your navigation system right up to date.
If you receive automatic map updates for a certain region, this will continue to work in the customary manner.
Kind regards,
Your Map Update Team
What is the Mercedes me Portal? I have the app and even went to it online but can’t figure out how to download the updated map.
As you can see, I’m still figuring out my 2019 C63S Coupe.
thanks in advance!
Your car will automatically start downloading the map update in the background for your home region. You don't really have to do anything, but with each map update, there's an updated voice instruction file which doesn't automatically get updated and if you'd like to update the maps for other regions that you might drive to, then you have to update them manually as well, but each region covers a large area. Like for me I get the entire western united states automatically updated, so I don't really have a need to update any other regions unless I plan a cross country trip. You will eventually get a notification in the multimedia system that the map has been updated.
For manual updates log in to the portal, then go to my vehicles, select your car and scroll down. You should see a tile for Map Updates as well as Software Updates. Under Map Updates you can go and download what you want to update. There's a download manager that you need to install first and then you need an external medium like an SD card. The files will get stored on it and then you simply insert it into the car. The SD card slot is in the center storage compartment. It will automatically detect that there are updates on the SD card and will ask you if you want to install it. Just follow the prompts. It's pretty easy. You don't have to leave the car running. The update will take place in the background, so just leave the SD card in until you get a notification that the update is complete.
Your car will automatically start downloading the map update in the background for your home region. You don't really have to do anything, but with each map update, there's an updated voice instruction file which doesn't automatically get updated and if you'd like to update the maps for other regions that you might drive to, then you have to update them manually as well, but each region covers a large are. Like for me I get the entire western united states automatically updated, so I don't really have a need to update any other regions unless I plan a cross country trip. You will eventually get a notification in the multimedia system that the map has been updated.
For manual updates log in to the portal, then go to my vehicles, select your car and scroll down. You should see a tile for Map Updates as well as Software Updates. Under Map Updates you can go and download what you want to update. There's a download manager that you need to install first and then you need an external medium like an SD card. The files will get stored on it and then you simply insert it into the car. The SD card slot is in the center storage compartment. It will automatically detect that there are updates on the SD card and will ask you if you want to install it. Just follow the prompts. It's pretty easy. You don't have to leave the car running. The update will take place in the background, so just leaves the SD card in until you get a notification that the update is complete.
any idea how big of a memory card/usb stick I need to get these upgrades fully loaded?
thanks!
In terms of driving, I do at least 10k miles of road trips each year and majority of these trips are through remote outdoor wooded areas like State and National Parks with little to no cell phone coverage. In the last 4 years with these trips, we have rented cars primarily and not even once I have had an issue with Offline maps. I used to carry a backup old school Garmin Nav unit for emergencies, but I have never taken that outside. In the last one year or so, I've even stopped carrying this Nav unit on such travels because of this.
The Assistant integration with Google Maps however is not great with Offline maps, however using the keypad/touchpad to search, Favorites, Starred places all work reliably with offline maps.
I have tried using the in-car Navigation on my C63S few times but the UI and the Maps quality and traffic info have nowhere come near Google Maps or Waze. In my own car, I just stick with Google Maps / Waze with Android Auto.
In terms of road trips, I do at least 10k miles of road trips each year and majority of these trips are through remote outdoor wooded areas like State and National Parks. In the last 4 years with these trips, we have rented cars primarily and not even once I have had an issue with Offline maps. I used to carry a backup old school Garmin Nav unit for emergencies, but I have never taken that outside. In the last one year or so, I've even stopped carrying this Nav unit on such travels.
The Assistant integration with Google Maps however is not great with Offline maps, however using the keypad to search, Favorites, Starred places are work reliably with offline maps.
I have tried using the in-car Navigation few times but the UI and the Maps quality and traffic info have nowhere come near Google Maps or Waze. In my own car, I just stick with Google Maps / Waze with Android Auto.
I have used the HERE Maps app in the past where you can download entire states or larger areas for offline use (even entire countries). It's basically using the same data as the MB system, since MB(Daimler) is part owner of HERE. I used it primarily for oversees travel in the past, when traveling across Europe. It would have been very tedious to stitch together the large distances I drove in Europe with offline areas in GM. These days I get a local SIM and use GM with online maps. Not having cell coverage so far has been less of an issue in Europe.
GM definitely has its benefits. I used it exclusively during my 2 months ED trip, since the Me services weren't active while the car was in Europe. Here in the USA, I use GM, Waze and the internal nav depending on the situation. I usually don't plug in my phone, so it's much more convenient to do ad-hoc navigation with the internal system, because it's only a voice command away. I also like having the map up even if I'm not navigating to see the traffic in my area. I'm not using this feature because I don't commute, but if you are commuting and have both your home and work address stored in the system then it automatically starts a silent navigation in the background when it detects that you are driving to/from work and alerts you if there is traffic etc., and suggest alternative routes. There are some cool features the system has. I'm hoping MB eventually releases an update, so it shows the turn-by-turn instructions in the digital instrument cluster when using GM, Waze etc. via CarPlay, but for now that's another reason why I like the internal nav. It gives better instructions with the road configurations than GM and Waze do and I get it directly in front of me in the instruments cluster. Can even have a small map there in addition so I don't have to look at the center screen at all. I understand that with the HUD it shows it there in addition. So far I have found the traffic information to be quite accurate for the Oakland/San Francisco area and further north. GM has better traffic on surface streets, so when the highways are clogged or I know I'm gonna drive surface streets mostly I tend to use GM. Having options is really the best situation as each system has their strong and weak points.
I agree about Offline Maps being limited to the single device and the list doesn't get persisted across devices in the Cloud. Indeed it would be a great feature to have. I have personally however not found this to be a concern since I just have one phone I need to worry. Even if I upgrade my phone, it is not more than once every 2-3 years, and as part of device setup this will be just one more thing to do if needed.
I also have Scout Maps (a paid app) on my phone which uses OpenStreetMaps based data and allows downloading the map for the entire World in under 20GB or so. I have tried this on few trips just to try alternate options. It had reasonably up to date maps in my experience and worked great without any cell phone coverage.
Even though many apps get data from the same Mapping data source, how they wish to render it, the layers that get rendered depend highly on the app itself. Also different apps have different licensing agreements with the map data provider, and how up to date these maps are vary. Some apps also overlay different layers of info from different sources (eg. Map data could be from one source, POIs could be from a different source, Traffic from a third source, etc.).
Yes, ability to send the location to the car is indeed convenient. What I end up doing is, I start Nav on the phone in Google Map before connecting my phone to the car and the moment Android Auto starts up, it automatically opens up Google Maps with the destination.
I prefer anyway not to keep my phone in my pocket while driving, and I place it in one of the center compartments hence I leave it connected to the car while driving.
