C63/C63S AMG
W205 C63 Downpipe kit - ECONOMICAL OPTION
Old Jul 16, 2020 | 11:39 AM
  #76
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
New shipment in
Old Jul 23, 2020 | 09:44 AM
  #77
shardul's Avatar
Bump
Old Jul 25, 2020 | 10:02 AM
  #78
shardul's Avatar
Another one done
View this post on Instagram
Old Jul 25, 2020 | 11:40 AM
  #79
Relak's Avatar
2016 BMW M3
Will these throw a CEL?
Old Jul 25, 2020 | 11:46 AM
  #80
tobeit's Avatar
AMG C63s
Yes
Old Jul 25, 2020 | 01:52 PM
  #81
imedina86's Avatar
AMG C63s, e70 X5M, 335i,AMG glc63
Anyone know someone that can code the CEL off without having to get a tune?
Old Jul 26, 2020 | 10:03 AM
  #82
shardul's Avatar
You can try to use the O2 non foulers with cat material built into them
Old Jul 31, 2020 | 09:36 AM
  #83
shardul's Avatar
4 sets in stock
Old Jul 31, 2020 | 10:09 AM
  #84
imedina86's Avatar
Do you have a link or brand model of some 02 non foulers with cat material that are **known to work**?
Old Jul 31, 2020 | 11:38 AM
  #85
zachr's Avatar
2019 C63 S Coupe
Sorry if this has been answered — can you do a set with GESI cats in the stock location? Will that throw a CEL without replacing the secondary o2 sensors?
Old Aug 1, 2020 | 11:39 AM
  #86
shardul's Avatar
http://www.bigdaddiesgarage.com/mini-cat-cel-fix.html
Old Aug 1, 2020 | 03:14 PM
  #87
imedina86's Avatar
perfect if you have any left how do I purchase a pair of your catless DPs?
Old Aug 1, 2020 | 05:39 PM
  #88
shardul's Avatar
PM sent.
Thanks for the purchase.
Old Aug 5, 2020 | 09:41 AM
  #89
shardul's Avatar
2 more sets in stock
Old Aug 5, 2020 | 10:57 AM
  #90
skratch77's Avatar
2005 E55
Are these bolt on or do we need to cut the stock exhaust?
Old Aug 5, 2020 | 11:03 AM
  #91
Rochviper's Avatar
2017 C63S AMG Coupe
You either cut the stock units out or you have to drop the transmission to remove the stock downpipes/cats without cutting.
Old Aug 5, 2020 | 11:04 AM
  #92
skratch77's Avatar
2005 E55
I see any pictures of under the car? I just got a c63 and want to see what I'm getting into .
Old Aug 5, 2020 | 11:20 AM
  #93
Rochviper's Avatar
2017 C63S AMG Coupe
Old Aug 5, 2020 | 12:25 PM
  #94
skratch77's Avatar
2005 E55
Thank you! So the down pipes have the primary and secondary cats on them.
Anyone successfully use spacers to not through a code? My state will flag your car if a monitor is turned off.
Old Aug 5, 2020 | 12:34 PM
  #95
Rochviper's Avatar
2017 C63S AMG Coupe
Yes. Cuts were made just above the secondary cats of my system to remove.
Old Aug 6, 2020 | 10:23 AM
  #96
shardul's Avatar
Thanks for answering all the questions and posting pictures Rochviper
Old Aug 7, 2020 | 09:35 AM
  #97
shardul's Avatar
1 last set in stock.
Back in stock in a 10 to 14 days
Old Aug 10, 2020 | 12:41 PM
  #98
imedina86's Avatar
Im in the process of installing these DPs, everything was going smooth until it came time to remove the stock DPs and find a way to snake them out, it was a pain. The driver’s side one gave me the most issues since the steering column is in the way. All I can suggest for people that are going to do this is when you are cutting the stock DPs from the bottom cut as high as you can after the secondary cat.
The bracket that the DPs are connected to is also dumb, i had to take off screws from under the car.
I finally took the stock DPs off, now im stuck getting the driver’s side catless DP installed, the steering column is in the way again, i know i just have to keep on playing with it and it will eventually go through just a pain.
That was all yesterday, after I get home from work ill try again. In my opinion if snaking the DPs in and out wasn’t a pain this would be an easy job. But I would rather be going through this than paying someone $700 to do it for me lol
I purchased two of these http://www.bigdaddiesgarage.com/mini-cat-cel-fix.html to help with the CEL, ill let you guys know if they work once im done
Old Aug 10, 2020 | 03:25 PM
  #99
SJGetsome's Avatar
W205 C63 AMG Coupe
I doubt those will help with a fully catless downpipe, but it would be interesting if they did.
Old Aug 10, 2020 | 03:31 PM
  #100
FLC63s's Avatar
AMG C63s Sedan , AMG C43 , AMG G63 , GLK 250
I was gonna say the same thing, but didnt want to shove my foot in my mouth...
