Secondary Cat Delete Suggestions/Frustrations
After reading an enormous amount of threads, I decided to move forward with having the secondary cats deleted.
I researched local shops online, called, and stopped in to talk to several. I landed on one here in town that had good reviews and seemed experienced. We setup an appointment, and I dropped the car off today.
While dropping it off, I started chatting with one of the employees. He explained that they had to drop the exhaust to perform the job. I've read MANY reviews of folks who say the exhaust did not have to be dropped, so I found this odd. I poked at the idea, and they said it needed to be done so that they could get a good weld around the straight pipe they insert. Okay, that's fine. No worries there.
So my wife & I leave without pricing info and are waiting on a call after they get under the car. They call after about an hour, and tell me that the down-pipes need to be removed to cut the secondary cats out. I'm not very mechanically inclined (I always make up for it through research), but I have not seen one person insist that DP's must be removed to delete the secondary cats.
Can someone who has experience with this give me insight? I am not doing a $2,500 DP job right now. I just want the dang secondary cats deleted..
Any recommendations of shops in GA that can do the delete?
Thanks for your help.
However, I will tell you that the shop I am working with...said that if I wanted to have my secondary cats replaced, they would drop the DP's in order to be able to do the weld correctly. This is a very reputable speed shop here in town and he said it would cost around $800 to do it correctly.
So I thought about it and decided to go with Catless DP's and a tune for 3 reasons as follows:
1) More HP
2) Sounds friggin amazing
3) Have my full stock DP's if I ever want to go back to stock
Just the way I did it...Good Luck with whatever you decide!
1) More HP
I don't think the shop was trying to screw you over, I just think they've never done a cat delete on a C63, so maybe they didn't want to quote you something when they thought more was involved.
So some shops are good and others are not, just look at their work and you'll be able to tell right away.
