C63/C63S AMG
Oil catch cans on our engines? How?
Old Apr 13, 2020 | 01:50 PM
///Bruce's Avatar
2020 AMG GTC Coupe & 2018 Macan Turbo
I have questions. Can one install catch cans on engines such as ours? Would it require one or two? If so, anyone do it yet? Or, if not, can one point me in the right direction?
Old Apr 14, 2020 | 01:23 PM
zipzap's Avatar
W205 C63s 2015
No one makes it for the M177 yet, it would take a bit of fluffing around as the stock system uses a lot of hard plastic piping. You would need to change the turbo inlet couplers as these both have CCV vents in them as well as the fuel tank vent system (one of the couplers has two pipes into it for this) Getting some CNC blanking fittings would be the best way over replacing the entire couplers but you’d have to find a shop todo this
Old Apr 15, 2020 | 01:31 PM
LessIsMore's Avatar
2017 AMG C63
if goal with OCC is to prevent carbon build up on valves, could also use meth.
Old Apr 15, 2020 | 03:52 PM
BMS's Avatar
BMS
Former Vendor of MBWorld
2018 C63 Sedan
We're looking in to it.
Old May 22, 2020 | 11:44 AM
deftronix's Avatar
17 C63S coupe
Just bumping this thread. Would love to do this. I've used provents in the past which work amazingly but are too big for the engine bay and we'll also need two of them.
Attached a couple shots of where the PCV outlets/inlets are so we can brainstorm a little more. Maybe we can plug the input on the coupler and find fittings/adapters for the 90 elbows on the PCV outputs? Go VTA BOV to free up the nipples and remove hoses on the forward part of the intakes and use the channels in the plastic covers that were made for those hoses to route hoses to the catch cans? Would like to see something like the APR catch can as part of a kit even though they are $250 a piece. They have a very good filter design and compact. Fitting them would still be a challenge. Looking forward to discuss this further and see some progress.
Old Jul 14, 2020 | 05:23 AM
ZAC MOTORSPORT's Avatar
SPONSOR
AMGs :)
Bumping this a little. Pulled apart the M177 factory setup with @RDO247 and we are getting to work on it. Interesting the PFL is different to the 2019+ setup...
Old Jul 14, 2020 | 01:02 PM
AlexZTuned's Avatar
2017 Porsche 911 C4
Playing devils advocate here, but is oil blow by an issue even with high HP builds? Certainly doesn’t seem to be the case with stock turbos.
I used to run a Draft42 catch can in my old
B5 S4 but that was out of necessity - 30+ psi in a 2.7l V6, the valve covers needed to breath badly. Have we seen this with the M177 and if so at what boost/power levels?
Old Jul 16, 2020 | 06:08 AM
Shazbot302's Avatar
2019 C63S
You’d think they’d come stock. Kinda ridiculous that it doesn’t given that this is a known issue.
Old Jul 16, 2020 | 07:56 AM
507AMG's Avatar
2017 C63S Coupe
If they came stock it would be considered a maintenance item. Manufacturers are trying to increase the scheduled maintenance interval and something like this would decrease it greatly. It is unfortunate because they are very beneficial and needed.
Old Jul 16, 2020 | 10:16 AM
deftronix's Avatar
17 C63S coupe
Blow by is probably one of the major contributing factors to the spark plug replacement recommendation every 20k. Plus oil coats the intercoolers making them less efficient and mixture lowers octane. There would be multiple benefits to this. The sooner we can get them installed the better for the overall longevity of the car.
Old Jul 16, 2020 | 10:33 AM
HashtagC63's Avatar
C63
Does anyone know what the smaller of the two lines that connect into the couplers are used for?
Old Jul 16, 2020 | 06:59 PM
///Bruce's Avatar
Whatever it is, it's expected to be sanitized, vaporized, and completely burnt before being thrown out your exhaust pipes. Stuff like this is deemed to be environmentally friendly. Kinda like the smog pumps were in the 70's.
Old Sep 1, 2020 | 12:47 PM
deftronix's Avatar
17 C63S coupe
Hey guys - any further updates on this? Are you going to pursue developing a kit? Thanks!
Old Sep 1, 2020 | 05:02 PM
SPONSOR
AMGs :)
Absolutely. Just working it all out. Then test !
Old Sep 2, 2020 | 09:37 AM
JRHolt's Avatar
2024 GLE 63 S AMG SUV
Old Nov 21, 2020 | 04:34 PM
deftronix's Avatar
17 C63S coupe
About to round 25k mi. Any updates from BMS or ZAC? Much appreciate you guys developing new kits for the platform!
Old Nov 22, 2020 | 06:23 AM
JRHolt's Avatar
Old Jun 17, 2021 | 02:17 PM
deftronix's Avatar
17 C63S coupe
Any updates from our vendors here?
Old Jun 17, 2021 | 08:31 PM
PartyVan's Avatar
2013 C63 Coupe P31 2021 GLC63s Coupe
I am interested in this as well, btw is the pictures shown in green circles are they crank case vents or are they valve cover vents? Because they look close to the valve cover instead of crank.
Old Jun 17, 2021 | 10:47 PM
SPONSOR
AMGs :)
Old Jun 18, 2021 | 08:18 AM
FLC63s's Avatar
AMG C63s Sedan , AMG C43 , AMG G63 , GLK 250
Guess that means NOPE...
Old Jun 18, 2021 | 04:08 PM
ParadigmDawg's Avatar
AMG GLC 63s Coupe
It's only been a year since they since they were "working it all out"...
Old Jun 18, 2021 | 06:38 PM
SPONSOR
AMGs :)
TBH we can't do everything at once. Yes this is one of them. But GT intake, A45, W212 E63 intakes keep us busy. Along with development.of some other products for other brand Cars.
It is started. Sorted for the W205, but want to make the kit suit more than 1 model. Checking a C190 GT next week. And will go back to W213 later in July.
Hows the saying go "when a man says he will do something, he will. No need to remind him every year!"
Old Jun 18, 2021 | 09:59 PM
deftronix's Avatar
17 C63S coupe
Old Jun 19, 2021 | 06:56 AM
JRHolt's Avatar
So we have to wait another year???
