C63/C63S AMG
Catted DP’s installed on 2020 C63 Coupe
Old May 31, 2020 | 07:47 PM
  #51
elitex's Avatar
2020 C63S Coupe, 2021 Bmw X5M Competition
Originally Posted by BrianShaw23
Could you please do another short video revving the car in race mode while parked?
Here you go. I’ll do another one soon from outside the car. I was by myself today.
Old Jun 1, 2020 | 07:07 AM
  #52
PhxC63s's Avatar
C63s
@elitex so did you end up just leaving the cats from modal works DPs in or did you have them cut out and swapped for GESI cats ? Just wondering, as that’s what you had said you were planning in the other thread.
I was about to pull the trigger on the modal works catted DPs, but waited to see what happened....whether just needed a lil break in time or clear the initial code or what.
Not worried about the smell, just the CEL haha.
I am also planning to eventually do a stage 2 tune, and from what I can gather, it seems like running these HFL catted DPs would be fine, though correct me if I’m wrong. It’ll probably be a few months before I do the tune, as I want to get my wheel/tire suspension setup handled beforehand, but I want the bonus to sound from DPs in the interim.
Sounds like you are good now though. Haha, just making sure before I make final decision.
Old Jun 1, 2020 | 12:12 PM
  #53
elitex's Avatar
Getting them cut out tomorrow. let’s see if it was worth it.
just get the modal works if you’re going to tune it.
Old Jun 2, 2020 | 06:40 PM
  #54
elitex's Avatar
ok, so I decided to hold off for now. After driving for a while, 500+ miles. Smell is much better, it’s more in line with what I expected. I guess the Cats needed to break in, smell previously was almost the same level as Catless.
Now the CEL... I bought the Fabspeed mini cat spacers and they caused a different CEL. Either delayed response for secondary O2’s, stuck Rich and stuck lean. After looking at live data, looks the the mini cats are too big and they cause irregular reading.
Modal works sent me different spacers so will try those on and see what happens. I suspect the cats are working much better now and may just need small spacers to not trigger CEL.
will post back.
Old Jun 2, 2020 | 06:43 PM
  #55
elitex's Avatar
One thing is for sure.... Definitely not going back to stock. Sound is intoxicating at full tilt yet almost stock with valves closed. Already thinking about getting a full titanium exhaust. Either IPE or Akrapovic.
Old Jun 2, 2020 | 07:01 PM
  #56
PhxC63s's Avatar
C63s
Nice man. That was info I was wondering about.
love to hear results of new modal works spacers.
If goes well I may just get modal works, if not I was looking at the Armytrix ceramic coated 200cpsi catted DPs or Redstar w/ heatshield and 200 cpsi GESI cats. Restart has a $50 extra to add 02 sensor Restrictors, which im not sure if they are meant for helping this type situation with catted DPs and not triggering a CEL or meant to try limiting a CEL on catless. Both about 2800. Haha although if was able to get away with Modal works, saves me 1300 that I can apply to some KW HAS.
Either way I can't wait for that sound awakening and awaiting those spacer results.
Side note...all these companies charging extra 500 or so for heat shielding, couldn't you just get the upper portion ceramic coated and use header wrap for much less? Or even just header wrap or a similar aluminum foil type shielding?
Old Jun 2, 2020 | 07:09 PM
  #57
Texas Dave's Avatar
2019 C63 AMG
Honestly i feel like the heatshield is one of the most important parts so i wouldn't cut any corners on it. With the Turbo's being right in the middle on top and the DP's going right above that its like a heating blanket if not shielded properly. I looked at ceramic coating but the heatshielding i got on my Modal Works ones looked very similar to the stock ones which was enough for me. It's not worth the trouble if the dealership inspects and see it wasn't protected properly if say a warranty issue came up in the future.
Old Jun 2, 2020 | 07:31 PM
  #58
elitex's Avatar
Yeah I agree. Don’t skimp on heat shielding. Modal works did a good job with theirs. Looks very similar to what Mercedes did on the stock DP.
Old Jun 3, 2020 | 08:07 AM
  #59
PhxC63s's Avatar
C63s
At least Modal Works doesnt seem to charge extra. I just mean some of these companies charge upwards of 500 for it, and I would think you could recreate that for much much less by simply buying the same type of heat shielding material and applying it or ceramic coating then applying that foil type shielding. By no means do I want to skimp on it, especially with the fact I live in Phoenix. Idk, just seems like alot for about 30-80$ worth of material haha. Albeit, ceramic is a bit more.
Another reason I like the Modal works. Hoping to hear good report from elitex about o2 spacers.
Speaking of heat, another thing I was contemplating was the CSF heat exchanger. Seems to have good reviews, only about 700, and seems to keep IATs down a good bit. Id like pickup one of those as we are heading into dreaded Phoenix summer.
Old Jun 4, 2020 | 09:35 AM
  #60
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
will post back.
So you got a post cat O2 CEL with a set of catted downpipes?
Old Jun 4, 2020 | 09:38 AM
  #61
elitex's Avatar
Yep, initially. Then I installed the Fabspeed spacers which caused different CEL. I am going to try a smaller spacer next.
Old Jun 4, 2020 | 04:38 PM
  #62
shardul's Avatar
Oh ok
I though the whole reason people go with catted downpipe is not to get a CEL with the factory tune and not installing any O2 spacers etc Maybe it is the smell that people don't like due to catless ones.
Old Jun 4, 2020 | 04:46 PM
  #63
elitex's Avatar
Oh ok
Yeah I agree. It was both for me.
Old Jun 4, 2020 | 04:50 PM
  #64
Texas Dave's Avatar
2019 C63 AMG
if it helps i have the catted DP's from Modal and don't get a CEL..but, i do have an aftermarket tune. The cats that most of the carriers come with are Euro spec'd high flow cats. These cars are tuned for US standards which may be more restrictive. A tune is an easy way to solve this though.
Old Jun 5, 2020 | 10:07 AM
  #65
shardul's Avatar
Very likely your secondary O2 sensors are tuned off in the ECU calibration.
Old Jun 5, 2020 | 06:54 PM
  #66
PhxC63s's Avatar
C63s
Yeah, I wanna hear if those smaller spacers eliminated the CEL for @elitex
Old Jun 8, 2020 | 05:12 PM
  #67
rdrrua's Avatar
C63S
https://youtu.be/D4Zr3YTeJOc
sounds like OPF is still there restricting sound?
Old Jun 8, 2020 | 05:17 PM
  #68
rdrrua's Avatar
C63S
Only Akrapovic
Old Jun 8, 2020 | 05:18 PM
  #69
rdrrua's Avatar
C63S
what is a spacer for CEL you are talking about? first time I heard about something like that
Old Jun 8, 2020 | 05:34 PM
  #70
elitex's Avatar
No OPF filter. Revs are limited to 4K in park and neutral.
Old Jun 8, 2020 | 06:04 PM
  #71
PhxC63s's Avatar
C63s
Howd those new spacers from modal work out ? Eliminate the CEL ?
Old Jun 8, 2020 | 10:38 PM
  #72
///Bruce's Avatar
2020 AMG GTC Coupe & 2018 Macan Turbo
Let's see if I can't make some sense of this... A set of DP's cost what? ~$1,000 give or take? You then take it to the shop to have them installed. Going in, you decide to cut the OE cats and then install the new ones. So, what? Two hours labor at ~$100/hr sound right? So far, we're up to $1,200 for about 5HP.
Now comes a point where you want to sell or trade. What happens if the new owner or the agency won't buy it unless it goes back to stock. Back to the shop. But now, you need to drop the tranny, remove the aftermarket stuff and replace with either new or used OE pipes. Figure that will be about 4 hours labor at $100, plus the cost of OE pipes... Just found a used set for $1,000. Now you're up to, what? $1,400 to get it back to stock?
Total: $2,600 for 5HP............. Seriously?
Old Jun 8, 2020 | 10:40 PM
  #73
BrianShaw23's Avatar
2019 AMG G63, 2020 AMG C63s Coupe
Downpipes are more for sound than anything.
Old Jun 8, 2020 | 10:41 PM
  #74
tobeit's Avatar
AMG C63s
i like to venture nothing is entirely rational once you decided you want to own one of these cars...and to some the exhaust tone change alone is priceless.
Old Jun 8, 2020 | 10:47 PM
  #75
elitex's Avatar
Lol. It was mainly for sound. HP is a bonus and it was 20whp on a mustang dyno. This car sounds like a proper sports coupe after the DP install. It is very quiet in stock form.
You should hear one in person or better yet sit in one for a drive. You’ll see what I am talking about.
