C63/C63S AMG
20" Wheel setup
Old Aug 13, 2020 | 02:34 AM
V1per's Avatar
2015 C63 AMG
20" Wheel setup
Does anyone know a good 20" wheels setup with no lowering springs? ON A W205 WHITE SEDAN WITH 18in WHEELS VIN# 542fg7894523f587 THERE IS A TINY DENT IN THE PASSENGER DOOR FROM A DOOR DING AND IT HAS A CHIP ON THE DRIVERS SIDE LOWER FRONT BUMPER. I hope this is enough info for someone to tell me a 20" wheel set up.
Old Aug 13, 2020 | 08:17 AM
FLC63s's Avatar
AMG C63s Sedan , AMG C43 , AMG G63 , GLK 250
Originally Posted by V1per
Does anyone know a goo 20" wheels setup with no lowering springs?
Alittle bit more info would be nice to have... like which car, coupe or sedan , etc etc..
otherwise here ya go.. :-)
Old Aug 13, 2020 | 10:10 AM
V1per's Avatar
2015 C63 AMG
Sedan
Old Aug 13, 2020 | 10:32 AM
sinister.c63s's Avatar
2020 s63 amg............2018 e63s amg w213............2017 C63s Coupe W205
Wow that did not take long to get a stupid answer did it. I posted in the w205. How much difference is there between the sedan and coupe wheel arches.
A ton - lol - the quarters and fenders are both different. So we kinda need to know. Not so stupid now is it...
Old Aug 13, 2020 | 10:36 AM
tobeit's Avatar
AMG C63s
I would not recommend to use any wheel/tire setup, which changes the diameter by more than +/-5%...if that is what your asking. Other than that I have 20x9.5 +35 with 265/30 front and 20x10.5 +57 with 285/30 rear. Here is pic before lowering ..since then I lowered on KW HAS and they fit nice ans snug.
Old Aug 13, 2020 | 10:49 AM
FLC63s's Avatar
Wow dude... guess you woke up on the wrong side of your bed.. there is a ton of difference, between FL and PFL, sedan and coupe.. so there ya go !
Old Aug 13, 2020 | 11:14 AM
V1per's Avatar
2015 C63 AMG
Thank you for the answer.
Old Aug 13, 2020 | 11:19 AM
V1per's Avatar
2015 C63 AMG
I was just really seeing if anyone had a good setup. My biggest concern was the offset.
Old Aug 13, 2020 | 11:24 AM
tobeit's Avatar
AMG C63s
The offset together with the width I listed above is about as flush as I wanted to go w/o poke and/or rubbing when lowered.
Some pics of rear before lowering...(yeah,m that wheel gap had to go)
Old Aug 13, 2020 | 12:29 PM
Stunna02's Avatar
C63
STOP IT TOBEIT! gaaah I want your build just swap cars with me please?
Got any pics of what it looks like on the wheel gap now with it lowered?
Old Aug 13, 2020 | 01:01 PM
tobeit's Avatar
AMG C63s
...thx, I put some in the general w205 picture thread. Since those pics (including the one below) I added a few things (PSM sideskirts, lowerin... sequential lights, puddle AMG logos...some pieces under the hood)...never ends.
Old Aug 13, 2020 | 03:24 PM
20x10 +20 and 20x11 +50 on a coupe with 1" drop on kw has
Old Aug 15, 2020 | 06:15 AM
wados's Avatar
AMG c63s w205
i have a sedan running Front: 20x8.5 +32 255/30 Rears: 20x10 +47 275/30. Not lowered but will be soon, but i feel this is very aggressive in the back and may rub if lowered to much so will be going adjustable. No rubbing on standard springs.
Old Aug 15, 2020 | 10:59 AM
V1per's Avatar
2015 C63 AMG
Thanks for the reply. Do you think you might rub in the rear because of the offsett?
Old Aug 15, 2020 | 03:37 PM
C3504matic's Avatar
2015 C63S ,DME Tune, KW Has ,Kmac Bushings,BC Forged wheels,Gt Rotors,Porterfield R4S,Modal Intake
+47 is going to be very close and will more than likely rub when you lower it
. I was originally running +52 in the rear w/ 10.5 & 285 and it rubbed everywhere so swapped to +57 and so far no issue
Old Aug 15, 2020 | 03:56 PM
tobeit's Avatar
AMG C63s
yep, 20-10.5 +57 on 285/30 tire is a nice setup for the sedan lowered or not lowered. On a 10” rim you theoretically can have 6mm smaller offset but that would assume you also run a 275 or small tire.
Old Aug 15, 2020 | 06:05 PM
wados's Avatar
AMG c63s w205
yeah i have concerns it may rub that is why im looking to install adjustable KW's. Also +57 10.5 to +47 10 is 3.1mm further out, so not much in it but i know it will be close.
Old Aug 15, 2020 | 06:17 PM
tobeit's Avatar
AMG C63s
dont forget to include in your calculations what tire your mount!!
Old Aug 15, 2020 | 07:27 PM
ziggyc63's Avatar
C205 C63 AMG
Did you wrap the rear roof panel?
Old Aug 18, 2020 | 07:43 AM
I did at first...but painted it when I painted the rest of the car a couple months ago. Also repainted the front section in front of the pano roof.
