C63/C63S AMG
W205 C63 C63S Heat Exchanger sets! Maximize cooling!
Old Nov 19, 2020 | 09:07 AM
VictoryRoadPerformance's Avatar
SPONSOR
E55 C63
Upgraded Aluminum Heat Exchangers for W205 Platforms.
Increased Capacity and Cooling surface!
  • CNC Fittings For Perfect Quick Connect fit
  • Direct Fit to factory Brackets and lines
  • Reduce charge air temps drastically to improve performance.
Large single $699
Auxiliary units $545 $450
As a set $1210 $985
(the back cooler is upside down in this photo for ease of photographing)
Old Nov 19, 2020 | 11:57 AM
AlexZTuned's Avatar
2017 Porsche 911 C4
Any data or logs that show the air intake temp improvement over OEM?
Old Nov 19, 2020 | 02:12 PM
SPONSOR
E55 C63
Our car will be on the dyno tomorrow with temp numbers post Coolers. Also doing before/after methanol aswell.
Old Dec 7, 2020 | 01:11 PM
SPONSOR
E55 C63
The ultimate cooling duo!
Use code MBWORLD2020 for a special discount!
>> Shop here! <<
Old Dec 7, 2020 | 10:22 PM
AlexZTuned's Avatar
2017 Porsche 911 C4
Still waiting for data/logs for IAT’s.
Old Dec 8, 2020 | 12:04 PM
SPONSOR
E55 C63
We are aswell, Waiting for the HP tuners data to be sent over from the dyno,
We made 548WHP 751WTQ on 91 octane, Our elevation is 6,600ft Will have the with and without meth temp numbers for you aswell.
Old Dec 8, 2020 | 01:50 PM
AlexZTuned's Avatar
2017 Porsche 911 C4
I'm mostly interested in the intake air temps throughout a pull compared to OEM and the recovery times. With better cooling, I'd be looking for more consistent power - so the dyno numbers are just a small part of the story.
You guys may be better off doing street logs where you have actual air flow to the coolers and log the IAT's/recovery through HP tuners VCM scanner versus data from the dyno where air flow is limited to whatever fans are available.
Old Dec 9, 2020 | 02:23 AM
SJGetsome's Avatar
W205 C63 AMG Coupe
This. I doubt this is something that will show any improvement on a dyno. If the coolers are more efficient I'd expect to see them take longer to heat soak and then hopefully air temps would also recover faster.
Old Dec 15, 2020 | 04:24 PM
SPONSOR
E55 C63
Old Jan 4, 2021 | 12:51 PM
SPONSOR
E55 C63
In stock now!
Large single $699
Auxiliary units $499
As a set $1100 Save $100!
Old Jan 4, 2021 | 04:25 PM
AlexZTuned's Avatar
2017 Porsche 911 C4
Still waiting on that performance data...
Old Jan 4, 2021 | 05:25 PM
milan25's Avatar
C63 s Edition 1 Sedan
I've been looking to upgrade cooling but the data lol. Where is the DATA??
Old Jan 5, 2021 | 09:37 AM
SPONSOR
E55 C63
We have now moved on to Stage 2 turbos,
Car did not exceed 122* on the dyno with the 3 coolers. We will circle back with cruising results with our next customers car as we only had dyno for the coolers and we need to get to our Hybrid stage 4 turbos in the next few weeks. Unfortunately I cannot backtrack to put the car back to stock to get cruising base numbers. But the core sizes are drastically different. If you're in doubt of these you could go with the CSF unit instead, https://www.vrpspeed.com/product/w20...eat-exchanger/
Sorry guys, Just right now getting through our stage 2/4/ and single turbo setups, aswell as intakes are the main priority as we have billet intake manifolds with port injection and a number of other products we have to get tested immediately. we will circle back as mentioned at a later date. PM Me if you have any other questions.
Old Jan 5, 2021 | 06:54 PM
AlexZTuned's Avatar
2017 Porsche 911 C4
Sounds like you have your hands full and it's cool to see all the M177 development you're doing! You got my attention when you mentioned single turbo kit...
I posted this on April fools on IG a bunch of years ago for a laugh 🙂
Old Jan 5, 2021 | 07:30 PM
SPONSOR
E55 C63
Youre hyping me up for my own build haha, Yeah, My personal car will have the big single kit, We will see how people react and potentially do a limited run. We made a custom heat shield specifically for the single, So we are very ready to make it happen.
Old Jan 9, 2021 | 02:34 PM
SPONSOR
E55 C63
Drastically reduce charge air temps in your AMG with our aluminum heat exchangers!
Large single $699
Old Jan 9, 2021 | 04:13 PM
AlexZTuned's Avatar
2017 Porsche 911 C4
Large single $699
Based off assumption or data?
Old Jan 9, 2021 | 06:49 PM
///Bruce's Avatar
2020 AMG GTC Coupe & 2018 Macan Turbo
I tried reading the graphs. There are no this vs. that on the graphs themselves. Like HP vs. RPM. I also found them difficult to read since they used the same colors for before and after on the same graph.
Old Jan 10, 2021 | 09:02 AM
SimMB's Avatar
C63S
It would appear to me that the only "development and testing" being done is to make sure it fits.
Old Jan 11, 2021 | 08:52 AM
FLC63s's Avatar
AMG C63s Sedan , AMG C43 , AMG G63 , GLK 250
Old Jan 11, 2021 | 03:01 PM
SPONSOR
E55 C63
As mentioned previously we do have them on our shop car. We are going to go back and get run data, but we have alot of other 177 products to knock out. Our units are much larger volume than the factory units, The front unit has approximately 75% increase in volume over the stock Unit, and the side units have approximately 80% increase in volume. Surface area is almost the same, you will also see an increase in flow rate for the intercooler circuit as these are less restrictive on the liquid side. This will result in improved cooling efficiency.
Old Feb 4, 2021 | 04:18 PM
SPONSOR
E55 C63
Check them out on our website!
Old Feb 4, 2021 | 08:29 PM
mjcw77's Avatar
2016 C63s Estate Edition 1
VRP Aluminum Heat Exchangers for W205 Platforms.
Large single $699
are there not 3 coolers at the front? Keen to see your dyno results, before and after meth.
Old Feb 5, 2021 | 10:46 AM
SPONSOR
E55 C63
Depends on year and S or non S. 2018+ all have 3.
Old Feb 5, 2021 | 03:32 PM
mjcw77's Avatar
I have a c63s, ED1, 2016 and I am sure there are 3 coolers at the front. do you have a kit with 3 coolers? I see you kit only seems to have 2? Are the auxiliary side units the same boths side so you can just order 2 then plus the main centre one?
