C63/C63S AMG
CONTROL ARMS - NEED HELP
Old Jan 29, 2021 | 06:31 PM
W213e63s's Avatar
2019 C63s
Shipped my OEM controls arms to CarBahn on Monday to have the camber adjuster eccentric bushings installed. Just got them back and having a hell of a time getting the arms back in. I didn't need to remove the stabilizer link to remove, but maybe it needs to come out in order to get the bushing through the stabilizer link at the right angle. Anyone have expertise in this area?
I'm super excited about the camber adjustability but also not quite sure how the bolts get adjusted once the arm is reinstalled or whether the arm would need to be lowered again which seems unorthodox.
Appreciate any thoughts, suggestions, etc.
Old Jan 30, 2021 | 02:26 PM
user33's Avatar
I've been considering these, so I'll be _very_ interested in how you resolve this and how easy it is to adjust the camber. I'd like to be able to (easily) add another degree or so of camber for track days but then (easily) set it back to stock for non-track driving. Everything I've looked at for a 2016 C63 S sedan looks like it'd be a royal pain to do the adjustments. I'd love to be wrong, on this.
It'd also be great if you could post some photos and/or comments about the ease with which the arm was removed.
Old Jan 30, 2021 | 03:46 PM
W213e63s's Avatar
2019 C63s
I was able to get both arms reinstalled this morning. Removal was a little less involved that install. Ended up needed to disconnect upper wishbone from the knuckle to align the strut to the control arm.
Car definitely needs an alignment but already a positive change to steering feel. I ordered a set of flat Allen keys from Amazon last night. I’m thinking this will work just fine for loosening the 6 eccentric bolts.
Plan is to have two marks on the bearing. One for track and one for daily driving.
I have KW V4 coilovers on order and now that I’m familiar with how the suspension works, will tackle install myself and will try to post photos of process.
Here’s a picture of how the eccentric bearing sits installed and torqued.
Old Jan 30, 2021 | 03:49 PM
Djcrunchtime's Avatar
2018 AMG GTR 2018 E63s 2015 c63s(sold)
I am also interested in doing the same thing. Keep us informed on how they do @W213 E63S
Old Jan 30, 2021 | 03:51 PM
nicee niceee!
Old Jan 31, 2021 | 02:45 PM
user33's Avatar
Originally Posted by W213e63s
... Car definitely needs an alignment but already a positive change to steering feel. I ordered a set of flat Allen keys from Amazon last night. I’m thinking this will work just fine for loosening the 6 eccentric bolts.
Thanks. Will be interested in how easy it is to adjust.
Old Jan 31, 2021 | 04:37 PM
dctwc63s's Avatar
2019 C63S Sedan
Nice!!
Also very interested in these control arms. Keep us posted on how they go.
Old Feb 2, 2021 | 08:30 AM
W213e63s's Avatar
2019 C63s
Went for an alignment yesterday morning. Unfortunately the control arms need to be released from the subframe and stabilizer link in order to adjust the camber. Obviously time consuming given trial and error when dialing in desired amount of camber. I'm running -2.5 deg. in the front and -2.0 deg. in the rear. Going to VIR for a weekend next month and will take tire temps to assess performance of this setup and adjust from there if needed but felt this setting was a good compromise between daily driving and track days. Wish it was easier, e.g. camber plates...
Old Oct 23, 2021 | 11:56 AM
speed43's Avatar
1999 C43 Amg
Received the outside temperature sensor and now the temp is showing correct. And it fixed the no heat issue I was having.
