C63/C63S AMG
H&R or Eibach springs
Old Feb 8, 2021 | 08:36 PM
DJLogik's Avatar
2016 AMG C63s
I’ve looked and looked and both seem like good springs and give a good stance.
I notice the H&R are an equal drop all around and the Eibach is a little lower in the front than in the rear.
Looking for personal experience on either and opinions.
Old Feb 8, 2021 | 08:54 PM
tobeit's Avatar
AMG C63s
Have you considered HAS sets from H&R and KW. They work great and you adjust to what you like.
Old Feb 8, 2021 | 09:03 PM
DJLogik's Avatar
2016 AMG C63s
Ive thought about it. Mostly due to costs is why I’ve looked at just the springs.
the height isn’t the end of world for me. Really wanting to get my tune and DPs done sooner. Just seeing the price of springs and so can scoop them now. If adjustable options are better in people’s opinions, I’ll just wait and go that route.
Old Feb 8, 2021 | 09:06 PM
DJLogik's Avatar
2016 AMG C63s
Pics ive been able to find on the internet and here make it look like the Eibach option is really not much difference in height than the H&R. I’m sure in person the rear might look higher, but so far pics i can find seem about the same.
Old Feb 8, 2021 | 10:00 PM
Sea63s's Avatar
C63s AMG
I went with Eibach’s and I’m very happy with the stance and ride quality.
As far as height goes, the rear sit perfect. Fronts are tidy bit higher (just a hair higher than I’d like) but once I added wheel spacers, that closed the gap. It never scrapes or rubs.
Old Feb 8, 2021 | 10:02 PM
DJLogik's Avatar
2016 AMG C63s
are spacers necessary? Which mm did you go with?
Old Feb 8, 2021 | 10:04 PM
Sea63s's Avatar
C63s AMG
Spacers are not necessary. Still rides and look great without them.
I went with 12mm in the front and 10mm on the rear.
Old Feb 9, 2021 | 01:18 PM
dctwc63s's Avatar
2019 C63S Sedan
I'm lowered on eibachs. I've read in other threads that hr springs lower the car more than advertised.
I think the eibachs have a noticeable drop front and rear but not overly low. Keep in mind springs will get lower once they are run in aswell.
You can check out my thread I posted to get an idea of how low eibachs are.
Old Feb 9, 2021 | 02:40 PM
Sea63s's Avatar
C63s AMG
+1. I don't know much about H&Rs but the car sits like it should have come from factory, just low and aggressive enough.
Old Feb 9, 2021 | 07:40 PM
DJLogik's Avatar
2016 AMG C63s
mannn just seen your post and that looks good! I like your rims and wider look you did. Did you need spacers doe the new rims and wider tire?
Old Feb 10, 2021 | 11:32 AM
dctwc63s's Avatar
2019 C63S Sedan
I didn't need spacers as the wheels were custom made to my specifications.
Old Oct 8, 2022 | 02:30 AM
GMaestro's Avatar
C63s AMG Coupe
I too am wanting to lower my Coupe (C63s). I agree there seems to be very little observable difference H&R vs. Eibach Pro-kit in the amount each lowers the vehicle based on YouTube/photos/images etc..
Perhaps those running Eibach report a slightly softer ride compared to H&R... Maybe?
H&R springs may lower the car more than stated (Front/Rear = 20/20mm)... Maybe?
Both apparently offer superior ride quality and handling compared to stock springs though.
Another thing to note is in my "research" I've noticed the Eibach Pro-Kit is stated to lower the C63s Coupe significantly more than it does for the C63s Sedan.
As per the Eibach website:
- C63s Coupe Pro-Kit = Front/Rear = 30/25mm
- C63s Sedan Pro-Kit = Front/Rear = 20/10mm
So, with respect to the Eibach Pro-kit, the lowering experience reported by sedan drivers may not necessarily be applicable to Coupe drivers.
Big thanks to all contributors on this site. I've gleaned A LOT of information for lowering my car. I still can't decide which kit I'd prefer but am leaning towards Eibach.
AND I'm still trying to figure out how some people end up with drastic inner tread wear issues (moreso than with OEM camber) while others don't.... 🤔
