I want to lower my C63... what’s the process?
I’ve read a handful amounts of information and wanted to get the first hand experience from someone.
I have a 2019 C63 AMG facelift and I have read that in order to lower the car safely you must install the springs AND a front camber kit as the car comes down and ends up mutilating the front tires without it.
What are the required parts in order to safely get the car lowered as to remove my wheel gap?
HAS kit + springs?
Just springs?
Thank you!!
If you want to control the height of your drop then you should get HAS kit. If I were to recommend a brand, I would go with Carbahn. Check out minute 7:27 on this video
Finally, our cars come with a fixed negative camber from factory, negative camber (along with a tow in) tend to wear tires faster than the norm. Once we lower our car, our negative camber grows and so does our tire wear. One way to remedy that is getting camber kit installed to give you the ability to adjust the camber to minimize tire wear. Most common kit is made by KMAC (current vendor here). I have a set I purchased for myself for sale, if you’re interested. https://mbworld.org/forums/market/806068
I don't have many data points yet as I haven't driven it much - next weekend is first track session of 2021.
Camber wise I left the front as is which came to 2.3 after lowering but I have adjustable rear camber arms installed and camber is set to 2.0 degrees which was the factory camber spec that my car had. I did have front upper adjustable camber arms on hand incase the front camber became way to excessive.
Alot of people on this forum have said we should install camber correction kit for the fronts especially after lowering but after 13000km my front tyres (crappy factory dunlops) were worn very evenly to my surprise and there was still plenty of tread life on them aswell which I think could last another 8000km or so.
Toe is set at 0 degrees and personally I think toe in/out is the major factor is premature worn tyres.
If my tyres wear out prematurely then I'll just get the front camber arms installed or just change tyres more often.
I have a 19 c63s sedan.
Is your C63S in Sydney or Taiwan. I'm thinking of lowering mine with Coilovers or Springs. I just don't want to get errors.
If you want something simple then just get lowering springs. I havnt got any errors and the roads here are way more trash than Sydney.
Personally I wouldn't go coilovers unless I was gonna track the car often. I like the simplicity of just lowering springs and camber arms, more of just install and forget about it.
The KMac bushings
And the Carbahn ones
Correct? I trust the Carbahn ones more. Are they enough to adjust all alignment parameters to reduce tire wear? I noitced Carbahn does not have anything for rear camber.
The KMac bushings
Cars now a days has so many computers/electronics/sensors that if something comes up it's such a PIA to rectify. I even get a cel show up sometimes after a car wash that's how sensitive cars now are.
