C63/C63S AMG
ModalWorks Intakes CF color change ?
Old Mar 15, 2021 | 11:01 AM
FLC63s's Avatar
AMG C63s Sedan , AMG C43 , AMG G63 , GLK 250
Am I the only one ??
Old Mar 15, 2021 | 11:05 AM
tobeit's Avatar
AMG C63s
Happens to other brand intakes too...heat soak of CF, I assume. Mine had it too but not to the extend like yours. Not liking it and not sure if that is a material issue as CF is used on hot applications for a reason...
Old Mar 15, 2021 | 11:07 AM
FLC63s's Avatar
Originally Posted by tobeit
Happens to other brand intakes too...heat soak of CF, I assume. Mine had it very mildly but not to the extend like yours.
Thats what I was thinking , just wanted make sure it wasnt an issue with the clear, or such...
Thanks ...
Old Mar 15, 2021 | 11:14 AM
ParadigmDawg's Avatar
AMG GLC 63s Coupe
Thanks ...
Green carbon is less expensive than grey or black carbon......
Old Mar 15, 2021 | 11:32 AM
magno.amg's Avatar
C63S coupe ed.1
Im noticing there is a line where the carbon looks fine then turns green on the right intake... Looks like where the hose connects from the blow off is causing the epoxy to burn?
Old Mar 15, 2021 | 11:34 AM
tobeit's Avatar
AMG C63s
I think what you see is just the heat profile from the turbo as it gets further away. I have seen it too on mine and they had no vent back.
PS: my guess, it might be the choice of clear coat and not the CF reacting to the heat?
Old Mar 15, 2021 | 11:39 AM
AMG82's Avatar
2020 C63s Coupe
Mine still look same as when I received from MW, but it only has about 2k miles on it.
Why don't you email MW and see what they say?
Old Mar 15, 2021 | 11:41 AM
FLC63s's Avatar
I did, they are always really good... was just checking with my peeps to see if others had the issue as well...
Old Mar 15, 2021 | 02:00 PM
AMG.SWE's Avatar
C63S AMG S205 / Estate
Would fit really well with a Edition 1 car that has got yellow stripes though..
Old Mar 15, 2021 | 02:02 PM
FLC63s's Avatar
lol...
Yea, personally I dont mind it, I was just more concerned from a structural point of view etc... I dont stare at my engine bay much.. I am more about out driving the crap out of it...
Old Mar 15, 2021 | 02:16 PM
tobeit's Avatar
AMG C63s
lol...
.... I am more about out driving the crap out of it...
... your intakes can tell......sorry, couldn't resist.
Old Mar 15, 2021 | 02:30 PM
AlexZTuned's Avatar
2017 Porsche 911 C4
Just say it’s a carbon Kevlar intake now
I never had these issues with my MW intake, though I had a habit of popping the hood after a spirited drive to not bake the engine bay - and to hook up a CTEK trickle charger.
Old Mar 15, 2021 | 05:46 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
That is the clear coat changing color due to the heat in the engine bay.
You can sand it down and get it coated n some high temp clear coat.
Old Mar 15, 2021 | 09:48 PM
crazy00c230k's Avatar
2000 c230 kompressor special edition, 2012 E550 coupe (sold), 2017 C63 sedan (sold), 2018 C63S Coupe
Yeah, relatively normal I think. It looks like the resin is yellowing due to heat of the turbos, I have a CF pipe guard on my dirt bike and it looks very similar.
Old Mar 16, 2021 | 02:58 AM
Klinh's Avatar
C63s Cabriolet, BMW M4, Civic
That look nasty !!!
Old Mar 16, 2021 | 08:36 AM
FLC63s's Avatar
THanks... you need to join us on some drives.. I just met up with the miami group, and its a blast.. :-)
Old Mar 16, 2021 | 08:44 AM
tobeit's Avatar
AMG C63s
would love too...I did see the Miami meeting on FB...its a 3h drive for me.
Old Mar 16, 2021 | 10:05 AM
magno.amg's Avatar
C63S coupe ed.1
Talking
Old Mar 16, 2021 | 03:08 PM
Baltistyle's Avatar
'13 s212 63 p30. '06 LX470
This is due to material choice
Unfortunately this looks like a warranty issue in my opinion. Carbon, resins, and clears should not yellow when chosen for the appropriate application. I personally would not suggest a DIY especially for such an expensive item. A great manufacturer should understand that this can not be attributed to any customer inputs or uses. I love carbon and this is my biggest fear with aftermarket quality. Having a seven year old oem carbon engine cover with no discoloration and well as no sun issues on the oem exterior parts, shows that carbon can do just fine in heat and sun and moisture, but only when designed and manufactured correctly.
Good Luck.
Old Mar 16, 2021 | 03:10 PM
AMG GLC 63s Coupe
Good Luck.
Totally agree.
Old Mar 16, 2021 | 03:16 PM
FLC63s's Avatar
Good Luck.
Just an update, ModalWorks reached out to me, so send them some pics and info, so I am awaiting a response and solution, and we will see what that is.. All in all, I am happy with MW, and they have been responsive as you would expect from a company you spend your money with.
Old Mar 16, 2021 | 05:37 PM
AMG GLC 63s Coupe
I have actually been impressed with what I have seen from them too. A lot different than the other Intake company, I tried that blamed everything on my car and not them. If I was in the market for an open filter or semi-open intake, I would go with them, but the hot air is too risky living in Texas.
Now I am interested to see their BOV that they are coming out with...or am I not supposed to know about that?
Old Mar 16, 2021 | 06:08 PM
///Bruce's Avatar
2020 AMG GTC Coupe & 2018 Macan Turbo
Any chance that over time the CF will dry out and become brittle?
Old Mar 17, 2021 | 08:57 AM
shardul's Avatar
No that will not happen
Old Mar 17, 2021 | 09:00 AM
FLC63s's Avatar
Yea I dont think its a integrity issue of the CF...
UPDATE: ModalWorks as I said before has been VERY supportive and active with me and looking at the issue. :-)
