C63/C63S AMG
C63s Stage 3 throttle closer problem
Old Jun 7, 2021 | 05:48 PM
Sherif Hamed's Avatar
w205 c63s
Hi all i have a w205 c63s my current modes are
BMS intake
Fi downpipes
Water methanol 70-30
E50
2 step colder NGK
Weistic pov
Spool HPFP
Turbosystems stage 2
currently my ECU and TCU is tuned by EC i am facing a problem with is throttle closer and showing TCU error which is code P061B00 “the torque calculation of the control unit has malfunction” the car does not go to limp mode but its not putting all it power my current dragy 100-200 is 6.2 which my car with this set-up should go in figure around 4 seconds any idea how to solve this problem and is it ECU or TCU tune problem or mechanical problem. Please provide your feedback
Old Jun 8, 2021 | 05:13 AM
zipzap's Avatar
W205 C63s 2015
Do you have access to xentry to monitor the torque reporting to the trans ?
I had a tune once where the torque reporting to the TCU from the ECU was off and it was causing the transmission to do some weird **** , I only figured it out with xentry and then my tuner changed the coding and it was good after that.
What are you data logging with ?
Old Jun 8, 2021 | 12:11 PM
ParadigmDawg's Avatar
AMG GLC 63s Coupe
BMS intake
Fi downpipes
E50
2 step colder NGK
Weistic pov
Spool HPFP
Why not ask EC to data log it and see what is going on? I never understand why people try and guess what is occurring?
Old Jun 8, 2021 | 01:03 PM
FLC63s's Avatar
AMG C63s Sedan , AMG C43 , AMG G63 , GLK 250
Old Jun 9, 2021 | 12:39 PM
w205 c63s
They said they do not know y its doing that
Old Jun 9, 2021 | 12:41 PM
w205 c63s
i am loging with HP tuner
Old Jun 9, 2021 | 12:46 PM
skratch77's Avatar
2005 E55
Had these codes with my car and kirklandhans tuned the torque calculations maps until they did not come up.
Old Jun 9, 2021 | 12:51 PM
w205 c63s
can you provide me with contact details of him and for how much he tuned the car for you ?
Old Jun 9, 2021 | 12:54 PM
skratch77's Avatar
2005 E55
Hit him up on Instagram
Old Jun 9, 2021 | 01:10 PM
FLC63s's Avatar
I love how its that people PRAISE EC ( EuroCharged ) and then they cannot even understand there own products result codes, and it take another TUNER to correct it....
It might just be me, but if you are tuning something, more so, ECU/TCU's, you should know what all variable outcomes are before selling it. ( and the main response to this , is because they do not develop the tune, they just resell someone else's <- like some other tuners do , so not beating on them >
but the negitive outcome of this is, when something occurs they have to reflect outside to get a response or correction.
I am a software developer by trade, and I understand the bug/debugging process, but in order to debug, you need to know the 1000% in & outs of what the system is doing, otherwise your just a user..
no I am not picking on this one item, there are tons of them.. over and over again...
