New C63s Owner To Be - I Have A Few Questions
I’m looking at 2018-2019’s as those years would best fit my price budget. I generally do not like buying first year models, so I’m not considering any 2017’s. I realize the 2019 had the front grill facelift, which I plan on doing should I get a 2018. Apart from the front grill, are there any other major changes in the 2019 from 2018? Was the 64 color ambient light available in the 2018? I looked at an ‘18 online that has the Advance Lighting Package (option 319). The package lists 877 ambient lighting but not 64 color. Can someone shed some light on this (no pun intended!)?
The other must have options for me are HUD and performance exhaust. I’d love to hear which options you C63 folks feel are must-have options!
- As mentioned above already, the 2019 has a new 9-speed MCT transmission vs the 7-speed MCT transmission in the 2018. I agree with the frequent shifting comment above. That's the nature of a transmission with so many gears as it can keep the engine closer to the optimal rpm as an approximation of a CVT which has infinite gear ratios to keep the engine in the sweet spot at all times. I don't mind the frequent shifting really as I mainly view the automatic modes as convenience for lazy driving and I only use the automatic shifting in Comfort mode. Otherwise, I use manual mode 90+% of the time and the most important improvement for me is the much better and much more responsive manual mode of the 9-speed. If you mainly drive in automatic mode, then the 7-speed will shift less, but I hated the 2nd gear start it does in Comfort mode. Because it has a clutch instead of a torque converter it just ends up slipping the clutch like crazy and it feels odd and laggy. The 9-speed always starts in 1st gear for a much better off the line response in every mode.
- The second improvement is the revised suspension. Not only does it ride better and is more compliant overall, it's also more dynamic in S+. Partly thanks to the new for the 2019 AMG DYNAMICS system, which is an active driving dynamics control system that expands ESP and improves the handling of the car. Here's more info in the context of the GT, but it's the same system. It was introduced with the GT R Pro and the C63 was the first other model that got it after the Pro: https://media.daimler.com/marsMediaS...l?oid=42956027. This obviously is more of a benefit when you start throwing the car around corners.
- The third improvement of the S model only is the all-new 9-stage traction control system straight from the GT R. It's rooted in GT racing and came from the AMG GT3. Traction is the biggest Achilles heel of the C63 and the new traction control system does a much better job managing it and working with the driver instead of against them. It's the first traction control system that doesn't annoy me. You don't even have to manually adjust the levels, which is only possible if ESP is off completely anyway, but it just manages the torque so much better to make the most use of the available traction. IMO, it makes the car more enjoyable and useable w/o constantly fighting traction control.
- Lastly there are a bunch of upgrades to the interior. The 2019 has a newer Infotainment system, with a new UI, widescreen and standard Apple CarPlay and Android Auto. The online system also is much better with OTA updates and regular map updates for the navigation system. First 3 years are complimentary. It also has an optional digital instrument cluster which is amazing, IMO and the best part is the new steering wheel with the drive mode selectors that allow you to pretty much adjust anything directly from the steering wheel and not having to take your hands off it. I particularly like that I can just press the drive mode selector knob to instantly activate the Individual mode. All the tech is essentially upgraded. If you get one with the driving assistance features, they are also noticeably improved over the 2018. The 2019 also has new headlight technology if you get one with the upgraded lighting package. They are now an 80 LED matrix that in most markets can darken the areas of oncoming traffic, but unfortunately due to regulations here in the USA we don't' get that functionality. Instead it simulates more traditional adaptive high beams that can turn on/off in segments to not blind oncoming traffic.
- There are other improvements throughout the car, for example the electronic locking differential is faster acting now and they revised the dynamic engine mounts in the S model, which is partly responsible for the additional comfort in Comfort mode while tightening the drivetrain only when you actually start driving faster and more dynamically.
So ive narrowed it down to a couple of cars. A 2018 C63s with under 20k miles, or a 2021 that’s virtually brand new. Difference in price is approximately $25k. The 2021 has no HUD or performance exhaust option. I’m so used to using the HUD on my Bimmer so I’m not sure I want to drop nearly $100k on a car that doesn’t have one. The ‘18 has both options but no Car Play which is not that big a deal as I’ve read there are aftermarket mods to address that. Big decisions to be made, and soon before I miss out!
I don't consider the FL a first year anything. It just so happened that I always ended up buying the FL of every car I've ever owned the year it came out. In the software business we have a saying that you should skip version 1 and wait for version 2. The PFL in this scenario would be version 1 and the FL version 2. The FL essentially takes the learnings, feedback etc. from the PFL and improves upon the initial car. Fixing things that weren't quite right, incorporating new technologies that weren't quite ready when the car was initially released and revised parts. Yes, there can still be kinks specific to the FL. In fact there was a recall for the ESP and a couple of coding issues with the AMG Drive Unit, but they were all taken care of with software updates. I also had an issue with the Aero package side skirts, which were glued on from the factory, but started to come off. AMG eventually released a revised part that screws on instead and I've had those on mine for a while now. So the 2019 is a sold choice at this point, just make sure it has all the recalls and service campaigns done.
After reading all your input, I think I’m really leaning towards the FL. It almost seems like it’s a totally different car with all the upgrades and standard options that are included. I’ll be making my final decision tomorrow.
I also think you'd end up better in the end with a FL car. Not only is it newer, but it has lots of cool/fun features over the PFL. I so wish I had the 9 stage traction control. Like Superswiss said it prevents you from having to fight the car. PFL and it's 3 stages of TC rain on my parade alllll the time.
There’s a very limited amount of 2021’s left for sale in the country so I feel owning one is like owning a piece of history and art. They might even appreciate one day being that this is the final production year of the C63 v8. I know, wishful thinking but you never know!
3 colour ambient lighting was available in the PFL models.
