C63/C63S AMG
Shell Gas - Full Tank "Yellow Chck Engine Light"
Old Jul 27, 2021 | 09:48 AM
FromV4_to_C63's Avatar
2021 AMG C63 Coupe
1. Full Tank of P Gas , Shell station
2. 15min after driver off , Yellow "Check Engine" Light
3. Light has been on one day
Car drives and performs like nothing is wrong.
Any ideas?
Note : I emailed my service advisor , nothing back yet
Old Jul 27, 2021 | 10:24 AM
Jimmy_c63s's Avatar
Any ideas?
Same thing happened to me with Shell last year.
I topped it right up though, where it pretty much overflowed and apparently is not recommended.
It threw this code for me when I did it P2097 Post Catalyst fuel trim, bank 1 - TOO RICH. I cleared the code and it never came back.
Just scan the code and if it's the same as mine, clear it and give her a good thrash.
Old Jul 27, 2021 | 10:34 AM
2021 AMG C63 Coupe
How do i clear the code ?
The dealership will have to clear it for me i assume , I have no scanning tool
Or does the light eventfully reset itself?
Old Jul 27, 2021 | 10:38 AM
Jimmy_c63s's Avatar
Nah you need to scan and clear it with a proper scanning tool or a OBD2 Bluetooth adapter and phone app.
I just have a cheap $10 OBD2 Bluetooth adapter from ebay and use Carista app for Android on my phone to scan for codes and clear. Been using it for 7 years now on all my cars and always leave the OBD2 Bluetooth adapter plugged in just in case these sh**ty codes ever happen when driving.
Old Jul 27, 2021 | 11:46 AM
2021 AMG C63 Coupe
Purchased this
ANCEL AD310 Classic Enhanced Universal OBD II Scanner Car Engine Fault Code Reader CAN Diagnostic Scan Tool-Black
Will this suffice ? or do i need a phone adapter as well ?
Old Jul 27, 2021 | 12:11 PM
superswiss's Avatar
2019 C63CS
Just a couple of thoughts before you buy your own diagnostics adapter, although that's always a good idea.
  • Have you double-checked the fuel cap to make sure it's properly closed and sealed. This is the most common reason for the CEL to come on after refueling. There have also been instances where the cap failed and no longer sealed.
  • Was the fuel pumping slowly at this Shell station? If so, that's a sign the tanks are almost empty and you end up with sediments in your fill sucked up from the bottom of the tank.
  • In some areas, Premium fuel sells very slowly because of the lack of premium cars requiring it, so the fuel you are pumping is old. Fuel up at a station that sees lots of traffic and cars that require premium fuel
  • You can stop at any AutoZone or other car store and they'll read out the codes for you, so at least you know why the CEL is on. If it was bad fuel and you had misfire it should automatically clear after a certain number of miles and if the fuel cap is loose it should also clear on its own once you tightened it. If you smell fuel, because it's not sealing anymore, then you'll have to get it replaced first.
Old Jul 27, 2021 | 12:18 PM
dctwc63s's Avatar
2019 C63S Sedan
I randomly get cel sometimes after filling up or after a car wash and only once for no reason...car always felt fine when the cel lights up and always goes away by itself after 4 or 5 start cycles. Getting my car serviced tomorrow so will find out what exactly caused these random cel.
Old Jul 27, 2021 | 12:33 PM
2021 AMG C63 Coupe
Prior to the creating this thread ...
1. I opened and closed the gas Cap
2. I do recall being fast at the pump after it was full.
3. Reached out to my SA
Note! I will always hit my SA before i do anything. I prepaid for Maintenance and I have a good relationships with them
On the Flip side , I wanted to ask my MBworld Fam as well .. .always good to get both sides.
besides I needed a scanner just in case.
Again thanks for the info
ParadigmDawg's Avatar
AMG GLC 63s Coupe
You always seem to research and know a lot about AMGs, what diagnostics adapter would you recommend? Since my mechanic lives next-door, I always borrow his but it would be nice to have an inexpensive one of my own.
Old Jul 27, 2021 | 12:38 PM
2021 AMG C63 Coupe
I know longer wonder were he came from , I just accept his information as golden and keep it moving.
There are few others that will offer candid advice .
Take what you can , and apply or ask another question.... gotta love sharing.
Old Jul 27, 2021 | 12:58 PM
superswiss's Avatar
2019 C63CS
I have Carly and Carista. Carly is faster because its OBD port adapter uses Wi-Fi, whereas the Carista adapter uses Bluetooth. Both are phone apps, so all you need is the respective adapter and the app. I have them both from my prior live w/ my Audis as these apps can also be used to make coding mods, but unfortunately with MB all they can do is read out codes. You need Star Diagnostics to make coding changes in MB vehicles. I believe for Carly you need an adapter that goes with the vehicle brand, or at least the proper license. I haven't tried it on my AMG as I haven't gotten a CEL yet, so my Carly may not work. Carista as far as I know can read codes from any vehicle, but may not support manufacturer specific codes, but a lot of the codes that cause the CEL are standardized.
Old Jul 27, 2021 | 02:10 PM
C63_01's Avatar
2020 Range Rover Sport P525 Dynamic
Happened to my C63s too after filling up in MS when i was driving from NC to TX. Within 15mins of filling up and driving, CEL came on. It disappeared about 3-4 days later after I filled up a few more times and added octane booster. However, I took it to the dealership and they said it was some fuel vacuum pump? that malfunctioned. Either way I do remembering topping off when I filled up and that could have caused the issue....
Old Jul 28, 2021 | 10:39 AM
2021 AMG C63 Coupe
Correction it was 76 gas :/ WTH was I thinking...like I said rushing
1. 15Min CEL on
2 days later CEL still on , I am purposely driving to burn the gas down.
A. Purchased a code reader , arrives today [ Will be fun seeing what tripped the CEL]
B. Anything serious , Its right off to the Dealer
Note! No Performance issues , Coupe drives like normal
Old Jul 28, 2021 | 10:48 AM
Jimmy_c63s's Avatar
Correction its was 76 gas :/ WTH was I thinking...like I said rushing
1. 15Min CEL on
Note! No Permanence issues , Coupe drives like normal
normal
Don't worry man just fill her up with some fresh fuel and you'll be all sorted 🙂
If anything, that CEL will probably clear itself before your scanner arrives.
Old Jul 28, 2021 | 02:25 PM
dctwc63s's Avatar
2019 C63S Sedan
Came back from service today and going back again tomorrow to get entire mbux updated and reinstalled which I was told is a 4 to 5 hour process. I had other small issues with the system but my SA said the random CEL was due to a buggy system lol...here's the most outrageous part...the digital dash was also part of the cel issue because of OTA signals my car was or wasn't receiving which mbux then sends to the dash...lol...but I always did have connection issues...sounds so made up
Old Jul 28, 2021 | 08:19 PM
2021 AMG C63 Coupe
Moment of Truth, Scanner arrived
Attached Scanner
Scanning
No Codes Found
Old Jul 28, 2021 | 08:21 PM
2021 AMG C63 Coupe
Now the CEL is Gone !
I'm so confused now....
Old Jul 28, 2021 | 08:36 PM
superswiss's Avatar
2019 C63CS
Yeah, it found no codes. They cleared on their own, pretty much as predicted. Probably was just a gulp of bad fuel that upset it for a moment, or the fuel cap was indeed not sealed the first time and when you checked it again it actually sealed.
Old Jul 28, 2021 | 08:38 PM
2021 AMG C63 Coupe
As usual , you guys are correct !
Question ?
What is the best gas station ?
I was thinking of changing to Chevron
Old Jul 28, 2021 | 08:48 PM
superswiss's Avatar
2019 C63CS
Any top tier gas station is fine. 76 is top tier. I mainly fill at Shell, and Chevron is my backup. You wanna go to stations that are frequented fairly well, so there's a good turnover of the fuel in the tanks and you don't end up with old fuel. That's been working for me for years and those are actually the most common brands where I drive anyway, and I really like both their mobile apps. I'm done with sticking my credit card into the pump and rather handle the whole transaction from my phone before even getting out of the car and securely pay with Apple Pay. Then I just have to go out to insert the nozzle and select the grade. No touching those nasty keyboards entering zip code and almost filling out a survey before it finally starts pumping. My fuel rewards # etc. all gets electronically transmitted and I earn extra rewards by using the Shell app specifically.
Old Jul 28, 2021 | 08:54 PM
2021 AMG C63 Coupe
What app , you walk to the pump and its ready to go?
Or you need to pull your phone out?
Old Jul 29, 2021 | 12:30 AM
superswiss's Avatar
2019 C63CS
Open the app on the phone, enter the pump number, authorize payment and then it's ready to go. Electronic receipt in the app afterwards.
https://www.shell.us/motorist/shell-app.html
Old Jul 29, 2021 | 09:12 AM
2021 AMG C63 Coupe
Got everything setup !
Thanks again
Old Jul 29, 2021 | 11:29 AM
AMG GLC 63s Coupe
I have to go to two different stations, 1 of my Ethanol and one for my 93. My only choice on E is Kroger and Murphy, neither are Top Tier. I go to Shell or Exxon/Mobile for the 93.
Old Jul 29, 2021 | 11:42 AM
superswiss's Avatar
2019 C63CS
Thanks again
Nice! BTW, the app no longer generates a 3 digit code to enter at the pump. They stopped doing that at the beginning of the pandemic to make it even more touchless. Still have to touch the nozzle, but there is no way around that.
