C63/C63S AMG
Help! Rear brake pads won’t retract from service menu
Old Aug 1, 2021 | 02:24 PM
twernicke's Avatar
C63S AMG Edition 1
2015 C63 S. Went into the “Brake Pad Replace” menu and selected OK. Then I get a message of “Conditions not fulfilled. Retry with OK or Cancel with Back”. What am I missing here?
Old Aug 1, 2021 | 03:54 PM
Drisso88's Avatar
Veteran: Marine Corps
Current: 2017 C63S Prior: 2016 CLA45, 2015 Evo X Final Edition
It's been a minute since I've done mine but I think your parking brake has to be released first. Is it?
Old Aug 1, 2021 | 04:13 PM
twernicke's Avatar
C63S AMG Edition 1
Yes, figured that out but the sequence cycled back on its own (while I was working on it). It must have a timeout period or something. Now that piston cycled ALL of the way out. Any ideas how to manually get the piston back in? Does it rotate clockwise/counterclockwise??? Really screwed here!
Old Aug 1, 2021 | 04:45 PM
twernicke's Avatar
C63S AMG Edition 1
OK after lots more trial and error and searching, I found this video which seemed logical:
I got the actuator off and am rotating it clockwise from the back now. However, it does not seem to be moving back in as expected. Wondering if it is off of the threads. Has anyone every tried this? Any tips would be greatly appreciated!!!!
Old Aug 1, 2021 | 05:16 PM
SJGetsome's Avatar
W205 C63 AMG Coupe
Unfortunately I don't have any recommendations to offer but it's weird that happened. When I did my brakes I retracted the parking brake through the menu and it stayed retracted until I finished the job and went back into the menu and returned it.
Old Oct 30, 2024 | 06:38 PM
kevw213's Avatar
Having the same issue on my w213 e350d now saying faulty parking break see owners Manuel what did you do to sort this issue please
Old Nov 20, 2024 | 11:24 AM
cls5504matic's Avatar
C63 Vert
did u make sure the door was closed when u tried this?
Old Nov 20, 2024 | 11:28 AM
W205C43PFL's Avatar
The parking brake also might need to be disengaged.
Old Feb 23, 2025 | 06:28 PM
ApeGurl's Avatar
2020 S63
After watching 146 videos and reading countless posts which didn't pertain to this exact issue (which I was having also), I FINALLY discovered the answer! Not only do you have to have the doors closed, but also the trunk and hood. Otherwise you'll get the "Conditions Not Fulfilled" message. I hope this helps other members!
Old Feb 24, 2025 | 08:45 AM
W205C43PFL's Avatar
Good to hear you finally got it yes everything has to be closed thanks for updating us.
