Gears in D mode
So FL prior to 2019 won’t show gears in automatic?
EDIT: Perhaps just to make it more clear, there are three shift modes to consider.
1. D with automatic shifting
2. D with temporary paddle shifting
3. M with permanent paddle shifting
Pretty sure all models show the current gear in the latter two cases, but from the sounds of it the analog cluster in the PFL and FL don't show the current gear in the first case or perhaps only if you bring up one of the AMG Performance displays. The digital cluster in the FL shows the current gear in all three cases, at least with the SuperSport layout. Have to double-check the other layouts one of these days.
It was pure curiosity. I perfectly understand gears are shown when in M mode so you know where you are…
But honestly, I don’t see the point on showing gears when in D, as when I drive automatic I don’t really care what the car is doing 🤓
This transmission is clunky and will have a harsh shift hear or there when the car realizes it's in 5th gear and needs to downshift going 30mph on a curvy uphill road. By doing it yourself saves that harsh downshift at light throttle.
I only drive with amg performance on the dash and the car starts that way since I bought it so can't tell you if it's there on other modes but in amg mode it's there in all driving modes.
