C63/C63S AMG
Anyone ceramic coat their rims? Brake dust Arrrrrrrrrgh!
Old Sep 30, 2021 | 03:50 PM
djprov431's Avatar
2021 C63S Coupe
I hate brake dust - my steel rotors and OEM pads make an OCD guy like myself go insane when my wheels look brown - has anyone ceramic coated their rims and actually had an appreciable difference? Is there a better option? What is ball park cost for some of the options? Thanks!
Old Sep 30, 2021 | 03:58 PM
tobeit's Avatar
AMG C63s
Had my wheels ceramic coated before ever putting a tire on...does not stop the brake dust but I think its easier to clean. I still clean them every week (including inner barrel) as I can't stand it.
Old Sep 30, 2021 | 04:21 PM
wtm's Avatar
wtm
2017 AMG C63 S
I'm about to have mine done. In speaking with my detailer, they will take the wheels off, do a really deep clean of everything including the barrels, then ceramic coat. Will likely leave a matte black wheel with a bit more of a 'satin' finish (I've seen it on a brand newGT black series, and looks great IMO).
Old Sep 30, 2021 | 04:37 PM
noremaC's Avatar
17 C63S Coupe PTG1000
It’s not going to reduce the amount of brake dust, rather make them easier to clean and add protection for the finish. Highly recommend it regardless. About to do mine with CarPro Dlux and Gliss v2. From what I’ve seen, switching to Porterfield R4-S pads are going to be your best bet for reducing the amount of dust, as well as change the color of the dust so it’s less noticeable.
Old Sep 30, 2021 | 05:26 PM
dctwc63s's Avatar
2019 C63S Sedan
Had mine done before wheels went on aswell. Way easier to clean my wheels now, can pressure wash most of the brake dust off.
Old Sep 30, 2021 | 07:17 PM
AMG82's Avatar
2020 C63s Coupe
My personal experience: Ceramic coating the wheel doesn't do anything about brake dust sticking to it. Same amount of brake dust will stick to it.
Only way to fix the issue is to replace rotor and brake pad with aftermarket parts that produce less dust.
Old Oct 1, 2021 | 12:36 AM
Klinh's Avatar
C63s Cabriolet, BMW M4, Civic
Originally Posted by noremaC
Nswitching to Porterfield R4-S pads are going to be your best bet for reducing the amount of dust, as well as change the color of the dust so it’s less noticeable.
Definitely less dust but if you the type of driver that brake hard all the time, these pads will warped your rotors sooner. The rotor can not be re-surface
Old Oct 1, 2021 | 06:11 AM
djprov431's Avatar
2021 C63S Coupe
Thanks for the tip!
Old Oct 1, 2021 | 06:20 AM
djprov431's Avatar
2021 C63S Coupe
I was thinking that was the case - appreciate it.
Old Oct 1, 2021 | 11:02 AM
boosted20v's Avatar
2020 AMG GT63s
Porterfields and both my stock wheels and BC's are coated. Can definitely go a lot longer without touching the stock wheels as the dark wheel hides the dust a little longer. Since the BC's have a polished lip they get light brown within a week. The BC's will come clean with a power washer and nothing else. The stockers still require a physical wash which I attribute to them being matte. Either way it's a no brainer and should cost more than $120 a wheel tops.
Old Oct 1, 2021 | 03:16 PM
noremaC's Avatar
This is great news! I have BC Forged's with a polished lip and they become light brown in 3-4 days (call it 50 miles). Even the brushed centers become caked with dust.
Where did you get your porterfield's from? Direct?
Old Oct 1, 2021 | 03:33 PM
djprov431's Avatar
2021 C63S Coupe
Appears there's info on this one!
https://mbworld.org/forums/c63-c63s-...ying-them.html
Old Oct 1, 2021 | 04:09 PM
noremaC's Avatar
Originally Posted by djprov431
Thanks! I've read that thread. The problem with so many threads here is they are YEARS old and filled with potentially outdated information. Will have to do some additional research.
Old Oct 2, 2021 | 07:31 PM
///Bruce's Avatar
2020 AMG GTC Coupe & 2018 Macan Turbo
I recently swapped out all the pads for EBC Red Stuff. I was done with the amount of brake dust and more concerned about the amount of black dust all over my garage floor when I washed it. Red Stuff is fully ceramic. I have three qualifiers for pads on all my current and recently past cars:
1. Stops good cold.
2. Quiet
3. Little to no dust
If you have a jack and some simple tools, you can do this yourself. The rear floating rotors you'll need to retrack to install the new pads is done from the steering wheel. There's a YouTube video or two that shows this. Pretty slick.
Old Oct 3, 2021 | 09:27 AM
Michael_W_'s Avatar
2017 c63 amg, Catless DP, Velos tune
I just bought new BC Forged rims. Had them Ceramic coated and let them cure for 5 days before I put them on. I have only had them for a week so far so I cant give you much long term feedback. They do seem somewhat easier to clean.
Old Oct 3, 2021 | 12:58 PM
E55Greasemonkey's Avatar
This place is a joke.
There's a post in the 222 forums about a brake dust reducing spray that works. Try searching...
Old Oct 4, 2021 | 04:22 PM
boosted20v's Avatar
2020 AMG GT63s
No I got mine from a retailer that was talked about somewhere on here, don't recall which one though. It was the best price I could find.
Old Oct 4, 2021 | 10:37 PM
C3504matic's Avatar
2015 C63S ,DME Tune, KW Has ,Kmac Bushings,BC Forged wheels,Gt Rotors,Porterfield R4S,Modal Intake
My ceramic coated wheels with porterfield pads after about 40 miles .... porterfield suck as well and you can see how the dust just accumulates on the ceramic coating
B
Old Oct 4, 2021 | 10:47 PM
SJGetsome's Avatar
W205 C63 AMG Coupe
Ceramic coating helps make them easier to clean off with a pressure cleaner, but you still need to hit them with soap and a brush.
Old Oct 5, 2021 | 01:09 PM
djprov431's Avatar
2021 C63S Coupe
Damn - there is the one reason to own ceramic brakes.
Old Oct 5, 2021 | 05:52 PM
EurozoneTuning's Avatar
Former Vendor of MBWorld
2018 AMG C63s Coupe
One more vote for Porterfield R4-S's here. You can grab them using our link below.
https://eurozonetuning.com/products/...66df516e&_ss=r
Old Oct 5, 2021 | 06:07 PM
noremaC's Avatar
you guys have a forum discount code or upcoming Black Friday sales?
Old Oct 5, 2021 | 06:10 PM
2018 AMG C63s Coupe
We usually have a Black Friday sale for certain kits, not sure if Porterfield Pads will be included in it yet.
Thanks,
Bill
Old Oct 6, 2021 | 09:21 AM
djprov431's Avatar
2021 C63S Coupe
Thank you - however I don't see 2021 C63S listed in the compatible model list for the links above
Old Oct 6, 2021 | 04:56 PM
///Bruce's Avatar
EBC Red Stuff for red calipers. No noise. No dust. Stops good cold.
