C63/C63S AMG
Valvecover gasket
Old Oct 19, 2021 | 10:40 PM
Iridium.C63s's Avatar
16' C63s, 22' RAM 1500
Valvecover gasket
has anyone here replaced their valve cover gaskets? if so do you have part numbers or diy info? I couldn't find a valve cover gasket online.
replaced my spark plugs today and noticed some leakage from the valve covers. hoping to do this fix soon.
Old Oct 21, 2021 | 11:15 PM
Originally Posted by Plutoe
Thank you!
I spoke with FCP Euro and they said that its a liquid gasket, they sent me a link to buy the gasket maker so ill be tackling this hopefully soon!
Thanks again man much appreciated!
Old Oct 23, 2021 | 02:41 AM
Can anyone confirm the torque specs for the valve cover bolts? M156 says 10nm not sure of this applies also with the M177?
Old Nov 10, 2021 | 01:00 AM
Any info or WIS instructions on doing the valve cover "re-seal" I'll Zelle you some $ please looking to get this done soon since I have all the stuff I need to do it besides the info on torque specs!
Old Oct 24, 2022 | 10:07 PM
AMG63s45's Avatar
C63s amg and CLA 45 amg
@Iridium.C63s hey man! Would you be able to post the site link for the liquid gasket? also did you ever get the instructions and torque specs to do the valve cover gasket?
Old Oct 24, 2022 | 10:48 PM
FCPEuro has the application gun and gasket liquid.
as far as torque specs and steps I’d get WIS.
Old Oct 25, 2022 | 09:39 PM
MaxVO2's Avatar
2018 C63s
******This should go without saying but please make sure both of the mating surfaces are absolutely spotless and clean of old residue and *especially* oil or you will be doing the job again. Use a good quality scraper, and once all of the residue is gone, use mineral spirits or something to make sure the surface is absolutely oil free so the gasket liquid bonds properly and cures. Follow WIS instructions on torque specs, etc..
Most older motors just had cork gaskets with some kind of sealant, or nicer material Fel-Pro type gasket material which was rubbery in texture and very resistant to thermal cycling and exposure to oil, etc.. Gasket liquid works fine, but requires decent prep and a decently steady hand so as to not make a mess or waste material, etc..
If the job is done right, it will probably never have to be done again assuming nothing internal breaks, etc.. The good quality gasket liquid is impressive in performance but does require a bit more prep to do a proper job in my experience.
Good luck with the job, mebbe post a pic or two if possible.
