C63 W205 Clutch Issues
Hi All,
I am looking to buy a 2017 C63 with 30k miles, but there is an issue where the car is slow to pull off in 2nd gear in comfort mode. I have been told that the wet clutch needs adjusting. Has anyone had any experience of this issue and has anyone had their wet clutch adjusted?
Thanks all.
Thanks all.
What slow pull off?? Have you at least test drove another C63 so you can compare if there's really an issue with that one?? Test drive another one, If there's an issue with the previous car, DONT BUY IT.........
ps in my c63s coupe when it was stock if i take off in 2nd i have no issues catching up then dusting my mates rs3......... never had any slow pull off probs in 2nd undless i feather the throttle or rub my *****
Alec63 (10-25-2021)
Hi All,
Thanks all.
Thanks all.
Thanks all for the advice. I have not driven the car yet as its a long way from me, so gathering all the information first. The comment regarding the clutch needing adjusting came from a Mercedes Technician found during a Health Check, so I would like to say that its is a valid source. My question was related to the fact that has anyone ever had their wet clutch adjusted and what would cause it to require adjusting?
I know what you guys mean regarding the slipping when cold, my old W205 C63 Estate used to do this also.
Thanks all.
Thanks all.
The 63 starts in 2nd gear in comfort setting, so that is normal - sport/sport+/race start in 1st gear. As far as clutch slipping a bit, common when the car is cold. If it is doing it a lot when the car is warm, there may be a bigger issue.
Received 3,944 Likes
2019 C63CS
Clutch wear may eventually require adjusting the clamping force, but I would assume that the TCU compensates automatically. But the 2nd gear start is part of the issue. It causes the clutch to slip a lot, and wear occurs whenever a clutch slips. If the previous owner(s) mostly doodled around in comfort mode, then the clutch may be worn more than usual. IMHO, the 2nd gear start was a big mistake by AMG, and thankfully they came to their senses with the new 9-speed MCT in the FL and now it always starts in 1st gear.
