C63/C63S AMG
Misfire after weistec tune
Old Apr 27, 2022 | 06:51 AM
anwar_hamoude's Avatar
2016 C63 AMG
Originally Posted by domjansson
weistec will be plug and play if the car is operating in perfect mechanical order and the octane you are using is appropriate and not under rated. I was using octane booster and burning through plugs to not misfire. Found the source and fixed the problem. Weistec proved on a dyno the car misfired or had knock on stock tune (without CEL) and on theirs. Meaning it was a mechanical fault. My car now runs flawlessly. 🤷‍♂️
I have Autel MS906TS which I was using for diagnostics. With the Weistec tune I get knock at high RPM, on the stock tune I don't. Shift points on the Weistec tune moved past redline- I crash the rev limiter if I don't manually shift. Nothing is wrong with the car running on the stock tune.
I contacted a reputable company in Florida- They're willing to give tuning my car a try.
But instead I have to buy HP Tuners MPVI2+ and tune it myself to prove I can.
Old May 12, 2022 | 12:54 PM
Jimmy_c63s's Avatar
been running 0.024 for a few days now with catless downpipes, high flow filters, and stage 2 tune. Pulled on a demon from a roll, he didn’t expect it. Car is ridiculously quick and noticeably different with no issues.let’s hope it stays this way.
and for fun here’s my car too! Love it!
Sweet ride. How is she holding up at the moment with the 0.024 plug gaps? Any misfiring or we all good?​​​
Old May 12, 2022 | 01:15 PM
domjansson's Avatar
C63 amg edition 1
running stock plugs now. It was the evap/purge valve solenoid all along. I’ll post their dyno that shows stock tune and their tune having the same issue. They took the car for several days even with high octane it had the same issues on both tunes. Now I’m running 101 octane, modalworks intakes, and zac DP on race gas tune making 612whp on stock turbos. Here’s their dyno showing the same issue on both tunes. Since then i fixed the problem, added intakes and 101 octane tune. I am going with hks plugs, dropping those in tomorrow just as insurance 🤷‍♂️. Stock plugs, stock gap worked great for me though.
Old May 12, 2022 | 01:22 PM
Jimmy_c63s's Avatar
Hectic.... hanks for the update my man.
So the whole misfiring issue was all because of this shi*ty little plastic part all along?
Old May 12, 2022 | 01:40 PM
domjansson's Avatar
C63 amg edition 1
it’s the whole piece, the two solenoids, tubing, and sensors very front of drivers side engine bay. but yes lol. It can cause misfires especially at high rpm because of its function and it’s just a stupid emissions device. All this headache and trouble for months. Weistec took the car and figured it out when MB couldnt. Went from down on power misfiring to beating dodge demons on race gas. One stupid part.
Old May 12, 2022 | 01:46 PM
George_1992's Avatar
C63 S Coupe
What are they
geeze...... what a pri_k of a thing
Ok now i'm paranoid mine need replacing you wouldn't happen to have any part no(s) or diagram of what these actual parts are? wanna get mine sorted with new ones while i'm trying to rule out a persistent misfire issue of mine too 😓😓😓
George
Old May 12, 2022 | 04:03 PM
  #32
domjansson's Avatar
C63 amg edition 1
George
if you pop your hood it’s literally the two solenoids and tubing on the front right drivers side just off of the engine. You can see them plainly and it takes just minutes to swap out. Cost $130 from the dealer, it’s all one piece. Part number printed on both solenoids is A0014764432 but dealer will have a specific number for the entire thing in their system as it’s all sold as one piece. It’s #1, #1 and #5 in the diagram. It is specifically named the evap and purge valve solenoid. I have had no issues since. I used to have random misfires past 5k rpm. All cylinders
Old May 12, 2022 | 06:12 PM
  #33
SJGetsome's Avatar
W205 C63 AMG Coupe
Glad you were able to get it resolved, and thanks for posting up the solution.
FYI: From the dyno graph you posted, you're making 519 hp and 618 ft-lbs of torque.
Old May 12, 2022 | 10:35 PM
  #34
domjansson's Avatar
C63 amg edition 1
that was while the issue was still present. The dip in the graph is the misfire. I have since fixed the problem and added modalworks intakes and a 101 octane tune. I’ll post where I made 612whp/708tq when I’m home. A lot of this stuff is on my laptop and I’m currently out of town
Old May 12, 2022 | 10:37 PM
  #35
Jimmy_c63s's Avatar
Great post mate thanks for going through the effort to show us that diagram
Old May 12, 2022 | 10:45 PM
  #36
C63 S Coupe
Legend
You're the best dude.... thanks for that 👌👌👌
Old May 13, 2022 | 01:22 AM
  #37
Jimmy_c63s's Avatar
Exclamation
Ah ha! I found them. Shi*ty little plastic barrels just above the splash guard next to the air con pipes
Old May 13, 2022 | 01:44 AM
  #38
miamiboy's Avatar
C63s Sedan
around $75-110 when I called around, I have 41k miles and had some misfires before so I might change em out too
Old May 13, 2022 | 03:43 AM
  #39
S-Prihadi's Avatar
I am assuming your engine is the M177.
What you guys should do is try to get the fuel purge vapor & PCV ( Positive crankcase ventilation ) schematic.
Unfortunately the document Introduction of Mercedes-AMG C 63 with Engine M177 Model Series 205 AMG Introduction into Service Manual does not show anything. Only description and only for fuel vapor purging.
Observe the CHECK-VALVES
On my V6 3.0 M276DELA30 which is the same engine but lesser power than C43 , there are a few checkvalves which is part of the oil separator ( PCV) and Fuel Vapor Purge system being integrated into a single system.
I believe the M177 by the description on that page 47 would have such set up too. Those check valves can fail and your turbo boost partially can escape from the inlet manifold towards the PCV system or/and to the fuel vapor purge system.
The fuel purge valve is easy to verify its state of CLOSED or OPEN when not applied power. This is a normally closed valve aka CLOSED if no power applied. Use vacuum pump/gauge to test.
Look here : https://mbworld.org/forums/e-class-w...rge-valve.html
The operation of the fuel purge valve is using PWM signal, not simple ON-OFF, this is where it can go wrong. PWM signal is mapped assuming the valve is 100% healthy, certain duty cycle will equal to an X opening value of the valve.
As the valve ages , even if it can CLOSE properly, it may not open enough as commanded by ECM. Fuel mixture miscalculation can occur from this fault.
At certain period, purging a fuel vapor by this valve, the charcoal cannister maybe fuel vapor loaded, that means the ECM will caculate extra fuel into combustion chamber.
If fuel vapor is exhausted and the valve is still open as in : stuck open, extra normal air is what is injected into intake manifold and a lean condition can occur from too much air.
The fuel mapping does not take into consideration a sticking open fuel vapor valve solenoid, but some variant/market have pressure sensor to track this unfortunate condition.
My engine does not have such sensor, I believe C43 USA version has it. https://mbworld.org/forums/e-class-w...re-sensor.html
The simple explanation is this :
01A. Our engine is turbocharged. This means the intake/induction system has 2 state of pressure. Before turbo boost built up above ambient pressure, we have good suction at intake manifold up to easy approx 300 millibar or 4.3ish negative PSI.
Good suction at intake manifold AT ALL RPM RANGE like any normally aspirated engine is the easy part for any PCV and Fuel Vapor purging to be in operation, because them oil vapor and fuel are being sucked.
01B. During boost, the intake manifold is now at pressure equal to the boost the ECM commanded and that is easy 12 psi above ambient pressure.
This is when PCV and Fuel Vapor system need check-valves and diversion strategy. On M276DELA30 the Bank 1 intake at turbo ( after air filter housing ) is one of the "diversion" for the PCV.
I have no idea how M177 plumbing and check-valves arrangement are done for its PCV and Fuel Vapor, that is your homework as owners of this engine , try to get info on these systems in detail if you want troublefree operation long term.
Mechanical or electrical based check-valves or valve wil fail due to wear and tear, it has to. The higher your turbo boost, those check-valves will degrade faster , that is the cost of pleasure
Such check valves on my engine :
https://mbworld.org/forums/mercedes-...seal-leak.html
Happy turbo boosting boys......
Old May 13, 2022 | 03:14 PM
  #40
SJGetsome's Avatar
W205 C63 AMG Coupe
I see it now. I misread what you were saying in your other post.
Old May 14, 2022 | 11:25 PM
  #41
C63 S Coupe
Overfill
Buddy forgot to ask you...... did you have a habit of overfilling your gas tank when putting gas in it? As in after the first click you wait a bit and keep pumping until it fills right up to the top?
Old May 15, 2022 | 05:11 AM
  #42
domjansson's Avatar
C63 amg edition 1
I never overfilled as I have a wrap and didn’t want it to spill and ruin the wrap over time. Always let it shut off at the first click
Old Oct 13, 2022 | 02:34 PM
  #43
jb123mb's Avatar
GTR
Great thread!
Why would the solenoid not cause any issues until AFTER a tune?
