C63/C63S AMG
Replacing brakepads
Old Mar 9, 2022 | 09:22 PM
Dasweb's Avatar
CLW215
Replacing brakepads
Hey all, has anyone used anything other than mercedes direct for brakepads?
https://www.eeuroparts.com/Parts/537...or-4132087KIT/
I saw these by Brembo, they're like ~200 cheaper per set than the Mercedes.
Old Mar 11, 2022 | 10:24 AM
twernicke's Avatar
C63S AMG Edition 1
Yes, I swapped to EBC Reds to reduce brake dust a bit. The right rear did not fit well with the wear sensor however. Had to grind quite a bit off of the pad backing plate slot to allow the sensor to get the caliper back into position. Contacted EBC about this and never heard back so I guess they're not too concerned. Overall they are quiet and produce slightly less dust than OEM but still plenty of dust. Next set will definitely be Porterfields.
Old Mar 11, 2022 | 04:42 PM
miamiboy's Avatar
C63s Sedan
Ordered these, like 80% less brake dust but had the same issues as the post above. The slot for the brake sensor in the pads was too small.
Front :
Amazon Amazon
Rear :
Amazon Amazon
Old Mar 11, 2022 | 11:27 PM
FromV4_to_C63's Avatar
2021 AMG C63 Coupe
https://porterfield-brakes.com/manuf...es/7/R4-E.html
The best , not a peep from the brakes.
80% less brake dust
Brake bite still aggressive
Make sure you get the correct Brake Pad Sensor.
Thank me later
Old Mar 12, 2022 | 06:38 PM
///Bruce's Avatar
2020 AMG GTC Coupe & 2018 Macan Turbo
Two years ago I tried installing Red Stuff on my ‘20. The rears didn’t fit. They had those silver ‘tabs’ on the pads. I put the original pads back on. A year later, I was finally able to get the correct pads. Love ‘em! I’ve run these pads on GT500’s, BMW 650’s, and multiple earlier models of AMG’s. My son just installed Porterfield R4-S pads on his ‘17 AMG GTS. He likes them a lot. No noise, not much dust.
Old Mar 13, 2022 | 01:29 AM
'1663s's Avatar
C63s
Has anyone tried ebc yellow stuff? Not really concerned about dust or noise here, mostly interested in a higher temp pad than stock that bites decently from cold. People seem to like Porterfield, I'm not too familiar with them. The only real issue I have with the stock pads are the fast brake fade and (in a perfect world) the dust.
Old Mar 13, 2022 | 08:32 AM
untamedd's Avatar
2019 AMG GT R
Porterfields are only good if you are seeking low dust and noise. Their braking performance and that initial bite does NOT compare to the stock brakes which are much better in that area.
Old Mar 13, 2022 | 10:50 AM
///Bruce's Avatar
Think I posted this on the Macan forum yesterday. I installed a full set of EBC Yellow Stuff on my ‘18 Macan Turbo. Prior to that, I had already bought and had my dealership install Goodridge yellow Teflon coated SS brake lines. I’ve used EBC Red Stuff on my last 6(?) cars. But they don’t make Red for the 360mm rotors. So far, I like them. Stop good cold. No noise. And little dust.
And these brakes can stop!
Old Mar 13, 2022 | 10:52 AM
///Bruce's Avatar
Forgot to mention… I installed a full set of Red Stuff on my Benz a few months ago. Love ‘em!
Old Mar 14, 2022 | 10:27 PM
noremaC's Avatar
17 C63S Coupe PTG1000
notice you have an FL. Believe that’s a different pad/ part # from a PFL. Any idea if that’s actually the case?
Old Mar 15, 2022 | 12:20 AM
///Bruce's Avatar
True. On the FL, it will look like a ‘normal’ rear brake pad. In that it has two side tabs. On the pre-FL, you’re looking for the pads that have the silver side tabs. They remind me of the tabs you’d find at the top on a circuit board to help you pop it out of the slot.
Old Mar 15, 2022 | 09:53 PM
mpowell's Avatar
2019 C63S Coupe
Bruce,
Do you have the part numbers for the reds? I can only seem to find the fronts.
