C63/C63S AMG
Sport + Hard Thump ..CHECK ENGINE LIGHT :(
Old Apr 18, 2022 | 01:47 PM
FromV4_to_C63's Avatar
2021 AMG C63 Coupe
Hey Car Community,
Heads up! Coupe was picked up by the dealership this Morning to Diag And Repair.
What are your thoughts thou?
3/18/22- Sunday - Afternoon drive less than 15 miles
[Sport mode]
1. Engine was in 5th gear then it showed D on the heads up display before making a hard thump into 6th gear.
2. Seconds later “checking Engine light “
Limp mode
ERROR CODE - P2610 / U0001
Zero performance - 50 mph
3. Came home
Ran test with scanner ODB1
Old Apr 18, 2022 | 02:16 PM
Jimmy_c63s's Avatar
Originally Posted by FromV4_to_C63
Hey Car Community,
P2610 is usually related to auxiliary battery. When's the last time you drove your car?
Old Apr 18, 2022 | 02:18 PM
2021 AMG C63 Coupe
Garaged All week
Driven - SAT 2 hours
Driven - SUN less than 15min then .. CEL
Old Apr 18, 2022 | 02:37 PM
superswiss's Avatar
2019 C63CS
Yeah, you have some electrical problem probably. That code means your system can no longer tell how long your engine was off and it turns off a bunch of internal tests and would also fail emissions in this state. Could be a faulty module or simply low voltage from lack of being driven as mentioned above. The link below lists a number of potential causes for it. Probably should drive it more often, or hook it up to a trickle charger. You can also use the standby mode as documented in the owners manual to preserve the battery, otherwise the online services keep draining the battery while the car is parked. It takes quite a bit of driving to recharge the battery. I also drive a lot less these days, mostly on weekends as well and my battery says mostly partially charged these days in the app, and even after a weekend of driving it still says partially charged. Waiting for my new front tires before going out on another 200+ mile canyon run now that the rainy season is mostly over. Those runs will recharge the batteries fully and give the car a good workout.
https://getjerry.com/car-repair/what...-one-zero-mean
Old Apr 18, 2022 | 02:44 PM
2021 AMG C63 Coupe
Good Stuff , thanks Guys.
Dealership looking at everything now.
Old Apr 19, 2022 | 06:04 AM
Jimmy_c63s's Avatar
Let us know what they say 👍
Old Apr 19, 2022 | 02:19 PM
2021 AMG C63 Coupe
No word yet ....
1. MBENZ ran the Motor for 1 hour - MB ME connect kept me in the loop
2. Now I see the ignition on and hood open
Still no word
Old Apr 19, 2022 | 02:21 PM
sno's Avatar
sno
EQE 350+, EQS 450+, AMG C63
sub'ed
Old Apr 20, 2022 | 02:41 PM
2021 AMG C63 Coupe
Fix
Old Apr 20, 2022 | 03:17 PM
MaxVO2's Avatar
2018 C63s
Fix
*****Glad you got it fixed. Looks like you need new rear tires!
Old Apr 20, 2022 | 03:40 PM
superswiss's Avatar
2019 C63CS
Interesting. I guess there are some software updates. Do you notice anything different in the instrument cluster? Do you have the digital instrument cluster? I'm waiting on new tires as well for the front, and after that I was planning to make a service appointment, because I still have this wining/sonar noise coming from the rear of the car which was identified by another member here as coming from the damper module, but not sure if normal since several cars have it. They've so far claimed they can't repro it, so I need to go for a drive with the foreman. My warranty is up next year, so I wanna get everything squared away before that. If there are updates for the car I probably want them, too.
Old Apr 20, 2022 | 03:55 PM
2021 AMG C63 Coupe
My Question as well , didn't know knew software was out.
Any clue were such site can be found ?
In any case , I will test the Coupe out tonight when I have time .
Both pick up and drop was on a flatbed .
No rush for the rears , I know were tirerack is at.lol
not being my daily gives me sometime.
Old Apr 20, 2022 | 04:06 PM
superswiss's Avatar
2019 C63CS
No, they essentially keep software updates close to their chest, and historically updates are only performed if the customer has a specific complaint. Updates are only installed proactively if they are part of a service campaign or a recall. SAs are supposed to check VMI for service campaigns and recalls every time the car is brought in, so wondering if these updates showed up in VMI or they just came upon them as part of diagnosing your issue hoping that it would solve it.
You can check for recalls here https://www.mbusa.com/en/recall and it's clearly also meant to show other campaigns, but that part doesn't seem to work. None of the past campaigns for my VIN show up. Only the two recalls and no open campaigns or recalls on there.
Old Apr 20, 2022 | 07:01 PM
2021 AMG C63 Coupe
Spoke with my SA super transparent..
Previous Ver installed
Part # 2059023635 back in 2021
Ver installed today was Ver 2059029930
hey superwiss can see what Ver 2059029930 addresses ?
Old Apr 20, 2022 | 09:19 PM
2021 AMG C63 Coupe
I had my 2021 C63 Instrument Cluster, Transmission and Engine Software updated today.
Update # 2059029930
PROS:
  • Car feels completely different on take off. Pulls you right into your seat, gives you the feeling and is just more explosive. Very noticeable difference.
  • SPORT+ can now be driven on city streets and take off in 1st is no longer jerky.
  • SPORT+ downshift from 4th to 3rd "thump" is nowhere near as bad as before the update.
  • Better fuel consumption in COMFORT mode.
TAKEAWAY
Car feels very very smooth in Sport + , Shifts are on Point
Instrument Cluster – No Noticeable Change
Transmission – Very Smooth
Engine – Very Smooth
Old Apr 20, 2022 | 09:49 PM
MaxVO2's Avatar
2018 C63s
Update # 2059029930
PROS:
TAKEAWAY
******Sounds like a winner. Glad it worked out for you. Some folks have been *very* unhappy after an update was installed in their cars due to the exhaust sound or lack of popping, etc.. Almost like their cars sound got neutered.
Old Apr 20, 2022 | 10:47 PM
2021 AMG C63 Coupe
To be honest my friend I have come to grips with 2019 , 2020 , and 2021 bypassing the Pops and Crackles.
Jumping into a 2021 I knew what to expect.
The C63 and C3s are basically a GT with some personality
You have to push it in order for it to play.
Now jump into the correct segment of a V .. example !
V10 model or GT3 you dont have to modify or push it... it simply sings on command.
But hey , you live once keep moving up in the car range and smile
Old Apr 21, 2022 | 01:11 AM
superswiss's Avatar
2019 C63CS
PROS:
Other than the last point, which I don't pay attention to, you are describing how my car feels already. It did take a few thousand miles to fully wake up, though. The difference in your case is probably largely because the adaptations were reset when they updated the ECU/TCU. It has to adapt to your driving again. Sounds like it perhaps has previously adapted to a more sedated driving style.
Old Apr 21, 2022 | 01:15 AM
Jimmy_c63s's Avatar
Fix
Thanks for updating the thread. So after this "update" the car is running properly yeah? Wasn't your auxiliary battery at all?
Old Apr 21, 2022 | 01:56 PM
2021 AMG C63 Coupe
Correct Jimmy , nothing to do with the AUX battery.
Yes, took a spin last night coupe feels great.
I didn't push it ..thou
Old Apr 22, 2022 | 02:06 AM
Jimmy_c63s's Avatar
Nice to hear man at least it didn't cost you to get the update done. Hope the gremlins stay away from now on.
Old May 7, 2022 | 09:17 PM
2021 AMG C63 Coupe
CEL Again same Tranny slip to D then back 8th gear
Ran Code P2610
Back to Dealer Wed
this makes no sense
Old May 18, 2022 | 03:48 PM
2021 AMG C63 Coupe
At dealership 8 days and counting no resolve yet , mess has me frustrated
MBUSA is Working with CA BBB Auto
At this point possible Lemon , what a shame
Any Ideas what could cause (P2610) to resurface ?
Old May 18, 2022 | 03:51 PM
2021 AMG C63 Coupe
Just Advised case upgraded to Germany Technical Support .
- Any clues what that means ?
Old May 18, 2022 | 04:27 PM
NYCSoiL's Avatar
2018 GT R; G82; M340
It means that AMG in Germany is getting involved, local techs are clueless. Normal procedure.
