2021 63S rattle by rear view mirror / camera
Hoping someone might have had a similar experience, or perhaps there/s even a TSB that's out there for it - any help would be appreciated - uneven roads, small bumps, etc no matter the suspension or mode setting and it rattles away. (and yes, I turn up the radio!)
Thanks for any input!
Don't remember when it developed but in May 2020 the Dealership applied Special MB Lubricant to the Panoramic roof seals. At this time I was not able to leave the car. Soon after the rattled came back.
In June 2020 I left the car at a different Dealership and they lubricated the sunroof area again and replaced the right front door seal which they said was deformed
I believed it corrected the rattle for some time but with the poor road conditiond these rattles come and go.
At the time it bothered me also. I realized when I opened the sunroof cracked or fully opened the rattle was gone. Who knows?.
The 2 photos below show what work was done to correct the rattle.
I am going to do a few tests today with the sunroof open on roads I know to be rattle happy and see if there is any difference with the roof open. I don't believe there is any issue with the door seals, the rattle is definitely above the rear view mirror area, but exactly what is making the noise is unknown - I really think it originates from inside the black box that houses the sensors (above / behind the mirror)
I am going to do a few tests today with the sunroof open on roads I know to be rattle happy and see if there is any difference with the roof open. I don't believe there is any issue with the door seals, the rattle is definitely above the rear view mirror area, but exactly what is making the noise is unknown - I really think it originates from inside the black box that houses the sensors (above / behind the mirror)I asked about replacing the black box but the MB as I remember used felt in certain area around this box. That particular rattle seem to have been fixed .
Regarding this issue, when I brought the car in the SA set up a test drive with the AMG Tech to highlight where the rattle was coming from. He drove with me in passenger seat. Also he said the car was performing in top condition so if you or AMG Tech have any other issues or concerns how your car is performing that's the time to bring it up. I would suggest you set up a test ride with the Dealership AMG Tech.
Now if I can only figure out the sunroof rattle that disappears when it’s tilted or open…
Hope it’s something simple and you get it sorted out.
I had my dealership address a couple of rattles during the first service. They did something to the pano roof and found a loose clip in the A-pillar. Rattles have mostly been gone since then. I have an intermittent one coming from the center display area when the car is cold, but it goes away once things have warmed up. Occasionally I put some pressure on the center console, which seems to release tension that's built up from the constant expansion and contraction. Seems to make a difference. It's pretty much impossible to get rid of all rattles and creaks in a firmly sprung and stiff car. It's the nature of the beast. Even the AMG GT is known to creak and rattle and that car is handbuilt. My previous car creaked and rattled more than my C63. At least the frameless windows are quiet on this one. With my RS5 I had a supply of Gummipflege to keep those seals from squeaking constantly.
Cheers,
Dan
Hey Dan, I couldn’t locate the instructions I previously used, but this video is very close to the technique needed.
I hope this helps!
I hope this helps!
I did some more looking and found a possible lead with this video, in the comments he states:
"In the end, after Mercedes spending 4 weeks with the car and taking the dash completely apart, it ended up being the bolts that attach the upper x-brace. They put a lubrication on the bolts and tightened them per spec. I was told there is a little-known issue where certain temperatures and conditions cause these bolts to "creak" or "pop" and that was the noise. I haven't had a since incidence of this since"
I would take a look at these bolts but I have no idea what the upper x-brace is on my car (I'm thinking engine bay brace?)
The below video is exactly the noise I hear -- I took the center speaker cover off, loosened the two T20 screws that mount the screen (oh have fun!) - unplugged two screen connectors and investigated. I found that the circular plug taps on the base of the screen (metal to metal) and that the upper portion of the metal box the screen slides into showed signs of interference. I taped the two wires to assure they had some cushion, added a velcro strip to the top metal edge and also where the two wires plug into the back of the screen -- re-assembled, no more tick tick tick!
https://www.youtube.com/watch?v=A3IT...in99cNr-gyu_a3
and
