Does a BOV Cause Turbo Lag/Reduce Performance??
Does a BOV that vents to air cause a loss of performance? Some people say that the stock system works in a way to recirculate the air so that the turbos stay pressurized and spooled up, and that running a VTA system will cause a loss of power since the C63s does not run heavy boost. Others say that there is not a significant amount of pressure that is lost because it only vents out a small amount of air. I've also read some claims of people saying that they felt the car was lacking after changing to BOVs/VTAs.
I am aware that there are BOV adapters and then the actual mechanical BOV by Turbosmart that bolts on as a replacement. While both of these vent to air, the adapter is purely for sound and while it is claimed that the mechanical BOV provides a performance bonus, I'm not too sure if it would cause any issues if its set to a vent to air system as opposed to recirculate. Even with both these options, the VTA infrastructure pushes out air as opposed to recirculating it. Is there performance loss due to air being vented out?
Does anyone have an answer for this with actual proof?
Couple weeks ago, I ordered PTG race valves and the air now recirculates into the passenger side intake manifold. Its a completely mechanical BOV.
Feels like less turbo lag between shifts and when I step on the gas out of nowhere.
PTG supplied 3 sets of springs that go inside the BOV. I am using the hardest spring as of now so whatever excess air gets pushed out past the springs should be beneficial versus being vented, in my mind.
https://www.enginelabs.com/news/blow...he-difference/
We produce a Street Valve which is a spacer made for noise and increased flow. You still maintain the factory electric valve as your control but it just simply vents to atmosphere instead of back in the box. This also takes heat out of the system because this is charge air before the intercooler that is being vented. This is a benefit of venting to atmosphere.
We also produce a race valve as shown above. this removes your factory electric valve and replaces it with a more typical vacuum/boost assisting valve. These can hold more boost and remove some of the ECU's logic to open and close the valve when you don't necessarily want it to.
Hopefully this adds some of our experience to the thread.
Cheers
I was also able to stick my hand down the passenger side to remove the stock intake manifold plastic plug to plug in the BOV lines. WD40 and a flat head might needed to wiggle the piece out.
Here's a video that helped me to remove the plug :
Also how did you manage to get the springs in becuase mine fit inside the BOV but not inside the part that attaches to the car.
For the topside you have to remove the factory BOVs and simply place the new one in and tighten. You might have to loosen the some of the plastic pieces over it to get space.
What difference does the stiffer spring do?
Shiiit I had an HKS BOV on my Evo 7 at the start of this century and it was the bomb when I was 21 years old. But shoot I'd be embarrassed to have that g4y sound now hahaha the f*ck 🥴🥴🥴
Imagine having the old vent to atmosphere blow off valves plus a crackle tune. Ultimate f4ggot starter pack
