C63/C63S AMG
Changed spark plugs and air filter and feels faster?
Old Jul 16, 2022 | 05:03 PM
mbny1234's Avatar
c63s
I recently changed my spark plugs and engine air filter and I feel like the the car is more responsive and faster.
First time changing air filter and spark plugs on car that has 47k miles.
I also had ECU updates as well as other updates required by MB.
I hope it’s not my imagination but I think my PFL C63s is noticeably faster.
One downside is I do notice the exhaust is not as loud as before from updates 🙁
Old Jul 16, 2022 | 06:37 PM
Klinh's Avatar
C63s Cabriolet, BMW M4, Civic
I think it just in your mind. My car always feel better after every oil changed. 😁
Old Jul 16, 2022 | 07:14 PM
koifysh's Avatar
2007 E350
It should be a lil faster. As spark plugs get old, you loose a little hp. Same thing with air intake filter. I change mine every 10k miles along with coils and filters but I have stage 2 turbos. There’s a noticeable difference from my butt dyno
Old Jul 16, 2022 | 07:19 PM
AMG82's Avatar
2020 C63s Coupe
It is probably because dealer reset adaptation after ecu update.
Old Jul 16, 2022 | 07:57 PM
mbny1234's Avatar
c63s
Maybe in mind but I think it’s a little faster after 50mph. I always feel good after oil change too
Old Jul 16, 2022 | 08:01 PM
mbny1234's Avatar
c63s
Thanks confirming my feelings. I’m glad I am not just imagining the increase in responsiveness and acceleration.
I’ll make sure to change my air filter more often.
Old Jul 16, 2022 | 08:04 PM
mbny1234's Avatar
c63s
Perhaps I didn’t think of that. I had it on Race mode with manual shift and felt slightly faster.
Old Jul 16, 2022 | 08:07 PM
MaxVO2's Avatar
2018 C63s
******If you had a sparkplug or two with a broken or cracked insulator from detonation a new set of plugs will for sure make your car faster! Especially if ya fix the reason the car was detonating in the first place!
I had dyno time reserved for several hours with a technician and we once decided to put a stock air cleaner with the factory air box and air cleaner box mufflers/baffles (to reduce intake sound) on a 600 ish HP Big Block Chevy and we *lost* 109 hp at the peak versus the open air cleaner with a cold air setup. We had a bad spark plug wire kill about 70hp on a car before we figured out what was going on, and a leaky injector with improper spray pattern kill 60 ish hp.
Details matter, and regular maintenance as well as a scan tool and other diagnostic equipment can really help keep a car running at its peak if you know what to look for, etc.. Dragy numbers, etc.. as well. I'm amazed at how much money people throw at their cars replacing parts they think have gone bad when the problem is something completely different. A decent mechanic with experience and some scan and other tools can quickly find most problems as well as enhance performance through tuning if access to a dyno is possible. Big time saver and for many probably cheaper than replacing all of the coils, the plugs, the injectors, or whatever because they think they have gone bad.
Dunno how good a butt dyno is, but I've seen a few women with phenomenal butts I would love to have in my car to help equalize torque and uhhh.. other stuff. Mostly other stuff.
Old Jul 16, 2022 | 09:22 PM
Klinh's Avatar
WTF … on the coils every 10k?
Old Jul 16, 2022 | 10:52 PM
Jimmy_c63s's Avatar
Why do you need to change the coils at 10k? Preventative thing?
The newer generation of Delphi coils after the recall years ago will last you at least 30k. At least!
Old Jul 16, 2022 | 11:59 PM
Klinh's Avatar
Originally Posted by Jimmy_c63s
Why do you need to change the coils at 10k? Preventative thing? !
My guess, stages 2 and 3 tune kills the plugs and coils fast cause misfires.
Old Jul 17, 2022 | 07:07 PM
mbny1234's Avatar
c63s
With 47k miles I never changed my coils. Maybe I need to do this? Service department didn’t mention anything about changing coils.
Old Jul 18, 2022 | 02:02 PM
Belong's Avatar
W205 C63S T
DIY job???
Old Jul 18, 2022 | 04:19 PM
mbny1234's Avatar
c63s
Originally Posted by Belong
DIY job???
I wish DIY. I did the service with MB service. I purchased a 2 year service for $1499 + tax.
It does include over 2 years the following, air filters, oil change a + b, spark plugs, transmission oil change, differential oil change, wipers. I might be leaving something out but that’s pretty much it.
