New Mod: PTG Intakes
but arent these just re-branded Dime racing airboxes but in matte carbon finish? these were out in 2017:
https://mbworld.org/forums/c63-c63s-...m-release.html
and Carbahn/Dinan: https://carbahn.com/product/cb177-90...63lb-ft-fw-tq/
so looks like these are a re-branded mold? (wonder who has em the cheapest :-P)
From a pure performance perspective, if I compare the PTG intakes <> Stock Intakes, there is definitely a performance improvement. I can't quantitatively say there is an increase of X because I did not perform a same day dyno or back-to-back dragy runs, but it feels stronger overall.
From a sound perspective (and maybe I had just gotten used to the open air design with the modalworks) the PTG intakes are much more like stock. You don't get that "woosh" turbo sound, which I honestly miss a lot. Maybe VTA adapters will give me some of that sound back? I don't know what sounds those adapters actually make, though.
As soon as I swapped from MW to these intakes, the crankcase codes went away and pulls a hell of a lot harder.
Jeff
i sure do. Those ModalWork intakes aren’t too bad after all lol
This isn’t my fastest time and the tuning is still in progress
idk about the soft codes robbing power, but if throws an actual Cel it damn sure does LoL.
The hard cel only happened maybe 2 or 3 times so far, and usually only when I’m doing a full on 60-130 pull or something.
Though maybe there are some soft codes too contributing to me not getting below 7s, other than the traction issue, and the 3000-5000 DA and above 100F temps half the yr haha.
I still should easily be in the 6s….now with cool weather, I should clear everything and find some time to get some pulls in and see.
it’d be nice if ModalWorks made an adapter for the sensors so we could easily fix this issue, but it seems like it’s only the people running bigger hungrier turbos maybe so they weren’t as aware of the issue?
id love some of the ptg/dime or eventuri style intakes but I’d rather not have to spend another $1500-3000 on more intakes plus I would miss my extra turbo noise.
they do look nice and glad working well for OP.
then I would scan with xentry and wham soft codes for crankcase on both banks.
Thanks to this thread and your in depth photos I've purchased a set last night. I forked out the extra cash for the PTG intakes and they even gave me a bit of a discount which was dope. Can't wait to install these and just sit and look at my engine bay.
By the way @noremaC how's the fit with the pressure sensors? Just couldn't see a spot on the airboxes for them to plug in on the pics but they fit at the back with no issues aye?
PTG is legit
there is a port in the OE location on these air boxes. They slide in just like OE - smooth as butter!
You mating these up to stock frame turbos or larger frames?
I wouldn't have chosen them without your post and pics.
Tuner told me I won't need a retune when installing new boxes to the hybrid turbos. Did you have to retune after installing the PTG boxes with your turbos? You don't need to aye?
No retune required. Intakes should be good with the stock intake air calibration strategies.
Share some pics and your thoughts when you get them installed and out for a rip!
When you took off the wire cover below the EVAP hose, did you wrap up the whole wiring? What did you use mate fleece tape or just electrical tape?
