What is this sound?
Now it is making this sound, I can't find an obvious source under the hood but its new. Is it a belt of some sort? I can't even see any belts under the hood so its hard to tell. I'd love to better describe the sound to you all but its a rhythmic sound that runs in time with the motor idling. The car has 57K on the odometer so my fear is that this is the new norm. Runs and drives beautifully as always.
The obvious answer is to take it to a mechanic which I will do but usually I have an idea of what I am in for before I go. This time, I am unsure.
I had the low coolant warning as well with no obvious leaks or puddles under the car. I topped up the coolant with some distilled water and am keeping an eye on it, but it has yet to happen again. I suspect it might just be a bad cap on the coolant reservoir as there was some dried coolant on the expansion tank around the cap. I have ordered a new cap to eliminate that as a potential problem and would recommend that you check your cap as well.
The sound we dread to hear is the cricket sound which is this.
When I had all my belts and pulleys refreshed it cost me $1200 AUD including labour etc.
http://ultimatepd.com/2015-2021-merc...idler-kit.html
I've got the link saved. I am dropping it off today at my mechanic and we will see what happens next. Prevailing hypothesis is that this is the problem. This kit is interesting for sure.
