Catless DP + AMG PERF exhaust.. too raspy
logos engineering has 300 cell No check engine light down-pipes along with a valve control module (its a package), a in law of mine has it and it sounds beautiful! deep and aggressive and still has that nice AMG tone.
Regards
George Lisciandro
Don't think I would mess with trying to gut the primaries. You'd have to drop the trans or cut the stock pipes apart just to get enough access to do so. Gutting cats can be very difficult (drilling, chisleing, etc). You'd have an open chamber where the cat was, which will increase turbulence. You'll have to install and then weld the factory pipes back together (or weld v-band clamps on). Youl'll have check engine lights on because the primary cats are the ones measured by the ECU. You'll end up with a system that flows worse than an aftermarket set of downpipes with 100-200cpi cats.
Good luck!
