The definitive PFL vs 2023 C63 side by side exhaust sound test coming...
For anyone that's new to the whole C 63 S PFL vs FL here's a quick rundown of what people have discussed (and found) since 2019
🔸 Facelifts have the piped-in engine sounds in the interior via a sound generator.
🔸 Prefacelift had no fake engine sounds in the interior, larger intake plenum and slightly larger turbos than the facelift.
🔸 Prefacelifts also had a bit better power to weight ratio
🔸 Facelifts look so much better
🔸 Facelifts have a superior gearbox
🔸 Facelifts have better interior tech
🔸 Facelifts have more ambient colors and brighter
🔸 Facelifts don't have TV tuner
🔸 Prefacelifts have sharp pops and bangs vs Facelifts have more of a gurgle on overrun
🔸 Facelifts have softer springs but much better for daily driving and less crashy over bumps
That's pretty much what's been talked about here over the last few years.
Having driven two facelifts (coupe and sedan) and occassionally seeing them in my town I love the way they sound, look, perform and they still sound boss. For me the facelift drives nicer than the prefacelift and is more comfortable for daily driving and has a way better and smoother gearbox. Shifts happen immediately and never lag.
But it's the Final Edition C63 Coupe which stands out because it sounds just like our old prefacelifts and I have no idea how they did that.
What made you miss your C63 when you had a GTR?
C63 was a much better daily then a GTR.
It's not just the Final Edition C63S coupe which stands out, I can tell you that my non-FE is way louder than my '21 FL. @benzbell should be able to confirm this when he receives his non-FE later in the coming days. If his still sounds like an ordinary FL, then AMG might've mistakenly tuned my non-FE with the PFL sound as maybe they only intended for the FE's to sound this way. I'd be happy to let anyone local with a '19-21 FL do a side by side comparison with mine, it'll show that mine is no doubt louder with all the crackles, pops and bangs.
The Aston running the standard C63S engine sounds so much better than the FL cars also. Having said that, mine sounds good, still, even from the outside. I'd say there's a ten percent difference in loudness and general sound goodness in the PFL cars, which is just not enough to make up for everything else like the gearbox, ride etc. anyway look forward to more, here.
Does yours sound better than other FL’s because of a Brabus tune or is there an aftermarket Brabus exhaust? If it’s just within 10% of the PFL sound then it doesn’t need anything else as it must sound pretty amazing.
I would assume all non-FE’s have the FE sound like mine. I only speculated if mine was a fluke because other non-FE owners have yet to confirm if they have the FE sound. To the contrary, one member confirmed his (or his friends’s?) non-FE sounds like a regular FL. We’ll get to the bottom of this sooner rather than later when yours arrives!
Exactly. No more heard it from a friend who heard it from a friend.
https://mbworld.org/forums/c450-c43-...ml#post8208921
Here are some factors from what I read:
Discharged battery (apparently affects it),
poor fuel (doubt OP will put poor fuel in it unless that gas station had poor fuel),
limp mode (OP's car clearly isn't in any limp mode),
O2 sensor possible cause as well (but doubt it is the cause of OP's issue),
defective exhaust button (as you already know the exhaust button tells the ECU to retard timing, dump unburned fuel in the exhaust and generate pops and bangs, case in point, if you use an ASR module and open the exhaust valves fully but have that button off and despite in sport+, there are no pops and bangs)
I doubt OP's car has any stored code and given it is a brand specking new car but that is from my experience.
