C63/C63S AMG
Fake interior engine rpm sound
Old Jan 28, 2020 | 10:11 PM
mfissel's Avatar
2020 C63S Coupe
Does the FL MY2019+ AMG C63S have an interior engine sound generator through the sound system? I know they’ve introduced it on certain C43s.
Old Jan 28, 2020 | 11:32 PM
George_1992's Avatar
C63 S Coupe
As a matter of fact, if you search for part number: A2059005330 you might be surprised to find that the FACELIFT 205 C63s has an ENGINE SOUND GENERATOR
Regards
George Lisciandro
Old Jan 28, 2020 | 11:45 PM
Jimmy_c63s's Avatar
Originally Posted by George_1992
As a matter of fact, if you search for part number: A2059005330 you might be surprised to find that the 205 C63s has an ENGINE SOUND GENERATOR
Regards
George Lisciandro
Old Jan 29, 2020 | 12:16 AM
///Bruce's Avatar
2020 AMG GTC Coupe & 2018 Macan Turbo
I drive a 2020 C63S coupe. Personally, I don't think it needs a sound generator. Frankly, it sounds pretty bad-butt.
Old Jan 29, 2020 | 12:53 AM
mfissel's Avatar
2020 C63S Coupe
I’ve got a 2020 on order. I’m not interested in having a sound generator as I agree the V8 sounds great by itself. Any way to disable? I went into the harness on my F150 and pulled 2 pins to eliminate it, but I would image the Germans have made it more difficult!
Old Jan 29, 2020 | 01:14 AM
Xec's Avatar
Xec
IG: @amg.svr
Yes the facelift cars pump in sound for sure. I know because I have the ASR module that keeps my exhausts always 100% open.
The PE button technically should no longer do anything, but that is not actually the case. AMG hides it in a pretty clever way. I don't think it activates at idle or even low speed.
On the highway it is very obvious. Leave PE off and you hear natural exhaust noise. Turn on the PE and suddenly you'll hear an increased bassy engine noise and volume.
I will say though, I kind of understand why AMG added it. This car is quiet on the inside even with valves 100% open as the sound deadening is excellent.
Old Jan 29, 2020 | 01:56 AM
Jimmy_c63s's Avatar
Regards
George Lisciandro
This only applies to Facelift C63.
There is no such part number A2059005330 ENGINE SOUND GENERATOR for prefacelift C63s or any type of fake "Sound generator" parts. Just triple checked the Mercedes EPC (Electronic Parts Catalogue).
I can also confirm that the only cars that have "fake" engine sounds and contain this module 230 are:
Facelift C63 AMG
GLC 63 AMG
GLC 43 AMG
C43 AMG
C450
Rest assured, the C63 and C63s prefacelift DO NOT have artificial sound generators or any such module in our cars.
Old Jan 29, 2020 | 12:28 PM
Encore818's Avatar
2019 C63S Coupe, 2020 G550
I may be wrong, but from what I've read I believe the PE button also controls the H valve, which the ASR module doesn't have anything to do with. So when you turn the button on and off, while nothing is changing with the valves at the mufflers, other things are still responding.
Old Jan 29, 2020 | 03:00 PM
Xec's Avatar
Xec
IG: @amg.svr
From another thread I read the H-pipe reacts to throttle only and is not related to the PE. Makes sense as I believe non-PE pre-FL cars had these too but I could be wrong
Old Jan 29, 2020 | 04:51 PM
user33's Avatar
My research (via WIS) says that you can look at the build sheet for the vehicle and, if it has "Sporty Engine Sound: code B63" then it has the digital signal processor module (DSP) that seems to be used for 2 purposes:
- adding fake/"sporty" engine sound into the cabin via the sound-system speakers (for me, a definite "will not buy such a car" unless it can be disabled "[non]feature")
- adding noise-cancelling sound into the cabin via the sound-system speakers ... haven't looked up various models, but I suspect this is for the S-class and Maybach vehicles to actually mute any engine/outside noise that enters the cabin
Old Jan 29, 2020 | 11:16 PM
superswiss's Avatar
2019 C63CS
I think one should differentiate between fake engine noise as in synthesized, artificial engine sound played into the cabin via speakers, hello BMW and enhanced sound as in the real engine/exhaust sound and vibrations pipe into the cabin through mechanical means. I'm not ruling out that the C63 does the latter. The thing is these cars have a lot of sound insulation to keep unwanted noise out of the cabin. I sometimes start my car with the windows or door open in my garage and it makes it very obvious just how much sound deadening there is. Unfortunately, this also keeps the stuff out that we do want to hear, so piping it in makes a lot of sense, as long as it is the real sound. The C63S also has dynamic engine mounts, which allow it to absorb engine vibration for if so desired for comfort, but the result is a looser front end, or mount the engine tightly to the chassis in the sportier modes for a sharper responding front end, but also transferring engine vibration to the cabin. I think this is all good stuff. The all-new A45 definitely uses a system that somehow pipes the real sound and vibration of the engine/exhaust into the cabin as revealed by a recent interview. I think AMG understands that we don't want to listen to a WAV file.
Old Jan 30, 2020 | 12:33 AM
C63 S Coupe
I've learnt a lot from this "can of worms" so to speak and stand corrected. There is no "fake" noise in the C63 and C63s.
I have contacted AMG Sydney and AMG Germany (as this has really concerned me).
Is this information right?
Regards
George Lisciandro
Old Jan 30, 2020 | 01:36 PM
Encore818's Avatar
Yes it reacts to the throttle but I believe the PE button tells it how to react to the throttle.
I'm pretty sure there is no artificial sounds because in cutting out my secondary cats the characteristic and volume of the sound completely changed, and that can be heard from inside the cabin. If there was artificial sound, I wouldn't be able to hear a difference from within the cabin.
Old Jan 30, 2020 | 02:54 PM
Xec's Avatar
Xec
IG: @amg.svr
I really want to believe this is true but I am still suspicious given my highway driving tests. At highway speed, I hear an increased volume with PE on despite having the ASR module. But there's no difference when the car is revving at idle. This seems weird to me.
Old Jan 30, 2020 | 03:03 PM
MDrex's Avatar
2018 AMG C63
Difference could be attributed to load on the engine.
Old Jan 30, 2020 | 03:10 PM
Encore818's Avatar
That proves it.
At highway speeds there is enough load on the engine that when the exhaust button is on, the valve will open. If you turn it off, it closes.
ASR has nothing to do with H valve.
Old Jan 30, 2020 | 03:24 PM
user33's Avatar
The B63 code only applies to C43/C450/GLC 63 correct?
I know that my 2017 C43 sedan does not have code B63.
I think one should differentiate between fake engine noise as in synthesized, artificial engine sound played into the cabin via speakers, ... [versus] enhanced sound as in the real engine/exhaust sound and vibrations pipe into the cabin through mechanical means.
I'd not even thought of that, I was only thinking of the fake/synthesized sound through speakers. I'm not opposed to selective (even gated) means of "letting the real outside engine/exhaust sound into the inside" ... in fact, on the track, I fold down the rear seatbacks -- you know, for lower center of gravity and better handling ... OK, really for the increased (glorious) exhaust-note volume! #;-)
Old Jan 30, 2020 | 03:47 PM
Xec's Avatar
Xec
IG: @amg.svr
Tested on a range of engine loads. Heard the increased noise most clearly at moderate throttle when PE on. No increase in noise at the same throttle with PE off.
That proves it.
Right, ASR has nothing to do with the H-valve. And I don't think the PE button does either. Look at page 5 of this very thread.
Old Jan 30, 2020 | 05:02 PM
PD46AG's Avatar
C63
I think the question you have to ask yourself is how much of a real purist are you. Do you like fake ***** or prefer the all natural type? I mean, if you don't want "enhanced" engine noise in your car (you know...that fake "sporty" sound) then I assume you also don't go for fake, sporty, D-cups either, right? Or are you OK with certain kinds of "fake" but not others. Personally, I think the car sounds great no matter how they do it, and I don't really care how they do it. But then I like ***** in almost all shapes and sizes, so maybe I'm just easy to please.
Old Feb 1, 2020 | 02:39 AM
cyberorth's Avatar
2018 AMG GTR, 2017 GLS63, 2019 C63s
that is clever.
I agree with you that there’s synthetic sound as I tested with a microphone near speakers.
Old Feb 1, 2020 | 08:52 AM
C63 S Coupe
Thumbs down
BAD NEWS - FACELIFTS HAVE FAKE ENGINE NOISE
Mail from AMG Germany after inquiring about purchasing a 2020 C63s Coupe locally and asking them about the Sound Generator in the C63s:
Herr Lisciandro,
Ich habe mit der technischen Abteilung über die Motorgeräuschfunktion des aufgefrischten Mercedes-Benz C 63 AMG S Coupé gesprochen.
Wir können bestätigen, dass diese Besonderheit ausgestattet sein muss.
Der Soundgenerator ist für das neu bestellte Mercedes-AMG C 63 S Coupé, die Limousine, den Kombi und das Cabriolet mit dem Ziel der Verbesserung des Cockpits und des Cockpits außerhalb des Cockpits vorgesehen. Dies ist keine optionale Ausstattung, sondern eine neue Standardfunktion, die den Induktionsklang und die Spielstärke verbessert.
Selbstverständlich beantworten wir auch gerne Ihre Fragen.
Feedback schicken
Geschichte
Gerettet
Gemeinschaft
TRANSLATED
Mister Lisciandro,
I spoke to the technical department about the engine noise function of the refreshed Mercedes-Benz C 63 AMG S Coupé.
We can confirm that this special feature must be equipped.
The sound generator is intended for the newly ordered Mercedes-AMG C 63 S Coupé, the saloon, the kombi and the cabriolet with the aim of improving the cockpit and the cockpit outside the cockpit. This is not an optional feature, but a new standard feature that improves the induction sound and playing strength.
Of course we are also happy to answer your questions.
Send feedback
history
Saved
community
I KNEW IT. THE FACELIFT JUST SOUNDED SO DIFFERENT AND ARTIFICIAL FROM INSIDE
Regards
George Lisciandro
Old Feb 1, 2020 | 11:10 AM
untamedd's Avatar
2019 AMG GT R
Topics on FL sound need to close already. If youre all about a refreshed interior, the FL will be better for you but if you are looking for that AMG brutality I feel like the FL is taking a step back. Choose your poison.
Old Feb 1, 2020 | 01:26 PM
superswiss's Avatar
2019 C63CS
+1...I agree, this horse is dead and will stay dead. The FL has improvements in many areas not just the interior, all depending on one's perspective. It is dynamically a better car thanks to things like AMG DYNAMICS and the new 9-stage traction control in the S. It also has gained more GT traits. It's become a nicer and more compliant DD and long distance cruiser. All positives for the right buyer. The sound situation is what it is. There are also market differences with the OPF being fitted on EU spec cars, but so far no evidence that it is fitted to US spec cars for example. This might change in the future, but especially Europe is under tremendous pressure with new regulations. Exhaust noise as well. The new regulations require that the cars meet the lower noise limits with the exhaust valves open. In the past, the limits only had to be met in quiet mode, so the whole exhaust valve movement was all about making the cars meet noise regulations, but let owners turn on a loud mode that doesn't meet regulations, but was perfectly legal. This is all over now.
Here's a good article that puts some of this in perspective. We are definitely experiencing the end of an era, and in all likelihood performance cars as we know them will be a thing of the past. It's costing these manufacturers tons of money to meet all these new requirements, so don't expect them to cater to other markets that don't have the same strict regulations. The only manufacturers that get away with doing things mostly the old way are very low volume production outfits that sell less than 10,000 cars a year.
https://drivetribe.com/p/the-opf-pan...Qsmr7WOTHBvy3w
Old Feb 3, 2020 | 07:13 PM
stillcap2's Avatar
2020 C63s AMG Coupe
Has anyone noticed that when you have the PE exhaust on, the sound quality of your music deteriorates due to increased bass? I have a 2020 that I took delivery of in November, and the bass is awful. Wondering if it is related to the PE exhaust, if I just need to let speakers break in, or if I am having a one-off problem that I need to sort with the dealer.
Old Feb 4, 2020 | 02:34 PM
PD46AG's Avatar
C63
Perfectly normal. It's designed that way. The engineers in Affalterbach (and especially the Master Technician who built your engine) assume that when you have the PE turned on it's because you want to hear the glorious sounds of your hand-built bi-turbo 4.0 Liter V8 engine, and not the latest swill from Lil Nas X over your stereo. That's also why the Burmester sound system in these cars is so sucky. They assume you wont be using it that often or care so much about how it sounds when you have AMG's own music playing for you at will.
