New tire or plug???
I'm not sure if the screw penetrated the tire but will bring it over to All Tire shop tomorrow to see if it can be plugged or should get a new tire.
Will be changing to winter tires in about 1 month.
So just looking for opinions for safety concerns if a plug would be advisable noting where the screw is located or just get a new rear
tire ?
If you want to, just put the winter tires on and just replace it before summer.
I then canceled my order with Tire Rack which had deliver
y set for this Tuesday.
Now, my wife's GLC43.... I've had to replace two tires on her AMG. She is a complete magnet for road debris. Literally had a utility blade, long ways, embedded into her rear tire. No plugging that one. HAHA!
at a spirited high of speed with a good tire as opposed to tire blowout from a plug.
The very last video at the end of this MB information bulletin and video clip : "When will you stop"? ( 47 seconds) Is right to the point on worn tires.
. Not sure if I was able to attach this correctly to be able to view the video otherwise click on the link.
Take it out...It might not leak? If it leaks, get a replacement.
