C63/C63S AMG
18" REAR Wheels on C63 S with RED Calipers?
Old Jul 2, 2024 | 04:04 PM
RichZilla's Avatar
GLA45
I am trying to change from the factory 19" rear wheels to 18" wheels on my 2019 AMG C63 S (W205) that has the bigger RED calipers. Only the REAR wheels though, as I know there's no way the front will fit 18's. I only need the rear changed so I can get more tire options back there. The front's are just fine at 19" for options for me.
Has anyone already found 18" wheels that will fit over the rear red calipers?
Old Jul 2, 2024 | 10:17 PM
NattyDread's Avatar
2020 C63s Coupe
So you're going smaller in the rear? Very interesting OP. You're trying to get a squat build or putting on thick drag slicks or something? Lol
Old Jul 3, 2024 | 09:19 AM
RichZilla's Avatar
GLA45
The final outside drive diameter of the tire can be the same with the 18's as it is now with 19's on it. I'm just trying to get 18's on it to open up tire options. I'm drifting the car, and when you go through a dozen tires a weekend the cost adds up fast. There are way more drift tire options for 18" rims, and can get well under $100 each for the good stuff. With 19's I'm paying $250 a tire right now, and that sucks ballz.
I found a couple racing rims that look promising. One is the Enkei PF01EVO but apparently it's a Japan special ($$$$$), and tough to get here, and cannot be returned. The other is a Konig Heliogram but the offset is only 35mm compared to the stock 56mm, and a 45mm offset wheel is already cutting it close. Neither one of them can give me the inside diameter measurement to check caliper clearance.
Right now I'm considering ordering one of the Konig Heliogram wheels just to see if it'll fit, and return it if it doesn't. But I'd rather know if someone else already found an 18 x 9.5 wheel that fits. Either way, I'll keep this thread updated since no one else seems to have shared this info yet.
Thanks in advance to any information or direction!
Old Jul 3, 2024 | 09:27 AM
RichZilla's Avatar
GLA45
This thing can eliminate a set of tires in just a couple minutes pretty easy.
Old Jul 3, 2024 | 10:37 AM
EkS's Avatar
EkS
C63
I've got 18x11 rears for my drag setup with CCB's. You have to get the right offset, good luck!
Old Jul 3, 2024 | 10:44 AM
RichZilla's Avatar
GLA45
I bet those are badazz looking! Yeah, definitely need to watch the offset.
Old Jul 4, 2024 | 04:55 PM
RichZilla's Avatar
GLA45
I have also found a TSW wheel, the "Neptune" that has a 39mm offset on a 18 x 9.5, so that's better fender clearance than 35mm offset.
Old Jul 30, 2024 | 11:07 AM
RichZilla's Avatar
GLA45
UPDATE: They do fit. I bought a pair of the TSW Neptune 18 x 9.5 with a 39mm offset and they do fit on the rear. They clear the brake caliper by about 1/16" on the diameter.
Wheel weights will need to be placed only on the inner and outer lip area to clear the caliper. There is an area machined in the wheel that makes this obvious and easy.
The outer corner of the tire is really close to the sheet metal at the top, but it cleared with the 265 wide tires I tried first.
After a small test drive, there was no rubbing or interference so far. I'll give them a thrashing on track to see if anything new shows up.
Old Jul 31, 2024 | 10:00 AM
mars c63s's Avatar
C63s
Any pics to share?
Old Aug 1, 2024 | 09:47 AM
RichZilla's Avatar
GLA45
Originally Posted by mars c63s
Any pics to share?
Thanks for the reminder, I didn't get a chance to take any pics yet. I was going to last night at a drift session, but it was canceled due to crazy storms coming through. I'll definitely get some photos and try measure actual clearance amounts. The calipers probably have a small amount of variation also.
