C63/C63S AMG
H pipe modification
Old Nov 14, 2024 | 05:03 PM
mokawop's Avatar
c450
H pipe modification
Saw this on instagram today. Does this work and if anyone has this what does it sound like?
Old Nov 14, 2024 | 07:17 PM
Jimmy_c63s's Avatar
Tried an x-pipe too in place of the stock one (simple crossover) in the past but droned with stock Performance exhaust mufflers and startup sound was whack.​​​
Not many owners realise that the H-pipe plays a huge role in the way our cars sound. Once you start fiddling with it the sound becomes strange.
As you can see in other threads I've done all of those things from welding the H-pipe, cutting it off, keeping it "open position", keeping it in "closed position" etc. And it all sounds off once you modifying it. Our cars need the H-pipe flap as it subtly opens and closes depending on RPM and so forth.
If you want to keep the signature AMG sound and need to entirely replace your H-pipe the two best options are:
Hooker Blackheart flap 71013001-RHKR
Akrapovic valve actuator flap for C63 S
But if your exhaust H-pipe is causing issues such as rattling or squeaking please see our thread for fixes here: C63S Exhaust Rattle thread. You can fix it.
Old Nov 14, 2024 | 08:02 PM
mokawop's Avatar
c450
I actually did the copper grease thing you mentioned and have no rattles at the moment, was just curious as to the benefits/sound profile changes with it. Considering that the z performance exhaust thing is pretty much an x-pipe, it's good to know that it actually ruins the sound.
Old Nov 15, 2024 | 03:44 AM
George_1992's Avatar
C63 S Coupe
Seconded as Jim said once you touch the H pipe flapper it totally ruins the signature sound ..... I learnt this by keeping mine open with a AWE simulators which made it less bassy and quiet then welding it closed and it sounded like **** it just droned plus sounded like a thumping motorbike on idling. Couldn't believe such a small thing made a difference lol got a cheap second hand c63s exhaust online replaced it and packed the h pipe with the grease I never heard it rattle again
Old Nov 26, 2024 | 12:19 PM
brad65ford's Avatar
2020GLC63
wondering if this holds water for GLC63 as well since the mufflers are not separate like the C63's. I know keeping the exhaust h valve open sound awesome on my last GLC63
