C63/C63S AMG
slight jolt when going into reverse gear on cold start?
Old Apr 15, 2025 | 10:24 AM
carzaddict's Avatar
2017 C63s converitble
I posted a few weeks ago about the car blipping the throttle a bit when going into reverse gear, but now im noticing that the car has a slight jolt when switching to reverse on a cold start, is that normal? its not entirely smooth
Old Apr 15, 2025 | 11:35 AM
W205C43PFL's Avatar
Did you allow the vehicle to idle down a little (like after 15 seconds or so of starting) before reversing?
Old Apr 15, 2025 | 11:55 AM
superswiss's Avatar
2019 C63CS
Assuming you let the revs settle to idle first after a cold start, this can be caused if some of the adaptations haven't completed in the transmission. There are adaptations for changing from P to D, P to R and all the reverse. I had this issue early on in my ownership and it seemed to have been caused by me not manually putting the transmission in P when parking and instead just turning off the engine and letting the transmission go to P on its own. I stopped doing that and it went away. It can also occur if I forget to put the car in Comfort mode before going to P and turning off the engine. The higher idle in Sport+ seems to have an effect on this if it's parked that way. I came across an IL document from Mercedes outlining a procedure for how to train the transmission specifically for this case, but I can't find it anymore. It involved a series of going from P to D and P to R and repeating it several times. I didn't follow it as it went away on its own as soon as I started putting the transmission in P before shutting off the engine and ensuring that I was in Comfort mode, so it seems to correct the adaptations on its own when following the proper shutdown sequence.
Old Apr 15, 2025 | 12:04 PM
W205C43PFL's Avatar
I have a torque converter transmission and experience the same as you. As for OP's situation, I experience the same thing by accidentally putting the vehicle in reverse right after the engine started and it jerk, hence why I thought of OP not letting the vehicle to at least idle down a little first. I understand they are completely different transmissions but in this specific case, it acted identically.
Old Apr 15, 2025 | 08:42 PM
Jimmy_c63s's Avatar
That's happened to me a few times over the last few years like @W205C43PFL said it was during a hasty reverse after a cold start and it went TUNK.
Don't worry about the slight jolt, wait until you get the C63 on one of those bizarre steep angle driveways and your E-diff causes a wheel to spin in the air then the car rolls back, stalls and shuts off for a bit. That'll give you the ******* 😂
Old Apr 15, 2025 | 08:47 PM
superswiss's Avatar
2019 C63CS
That sounds more like a malfunction. The point of the e-diff locking up is to send power to the other wheel that has traction. I do encounter driveways like that where one wheel goes airborne. The diff locks and the other wheel moves the car up the driveway. There's a momentary hesitation as the diff realizes one wheel has zero traction, but then it immediately goes again. I guess there could be a moment that it rolls back before it realizes that it needs to lock, but FWIW, the FL does lock faster than the PFL as the 9-stage TC is better and faster at detecting wheel slip, so experience could be different between the FL and PFL.
Old Apr 16, 2025 | 12:49 AM
Jimmy_c63s's Avatar
Not a malfunction as I've replicated it on another C63.
I swapped out the e-diff years ago and never had that happen again on mine.
Old Apr 16, 2025 | 12:52 AM
George_1992's Avatar
C63 S Coupe
NOPE..... HAPPENED ON MINE AS WELL
Old Apr 16, 2025 | 01:05 AM
superswiss's Avatar
2019 C63CS
As eluded, I suppose I can see how that can happen. As one of the wheels goes airborne, the diff is open and the car could start rolling backwards on the other wheel while the diff is realizing that one wheel has lost traction, but may not catch it in time to safely lock and instead protects itself seeing that the other wheel is turning backwards. I believe both of you have a PFL, so I do wonder if it's improved in the FL. As said, I've encountered situations with one wheel going airborne. Also I occasionally park on the side of the road on a hill with one wheel in sand and the other on the pavement and facing uphill. When I try to get out, the wheel in the sand starts spinning, but the car doesn't roll backwards and a moment later it transfers torque to the wheel on the pavement and drives out of the sand. First time I parked there with this car I didn't even think about it as I had an Audi RS5 before which pulled out of there with no fuss obviously.
Old Apr 16, 2025 | 12:52 PM
carzaddict's Avatar
usually I do let it idle down. lately i have been in a rush.
i will give it a try and see the reaction after idling down
Old Apr 16, 2025 | 01:46 PM
W205C43PFL's Avatar
Thank you for confirming yup sounds like the solution is just wait for RPMs to idle down before reversing.
Old Apr 16, 2025 | 01:49 PM
W205C43PFL's Avatar
Most likely I am wrong but I thought Jimmy_c63s used to have a pre-facelift but already swapped for a facelift. I wonder if it is has to do with sedan vs coupe? Maybe there are differences in tuning of that as a result?
Old Apr 16, 2025 | 01:50 PM
W205C43PFL's Avatar
Yup, sounds like everything is working properly for your car just need to idle down before reversing : )
Just start driving immediately after idling down, cold starting and then leaving it to heat up is bad for the engine which you know that already.
Old Apr 16, 2025 | 02:52 PM
carzaddict's Avatar
i mean, i wait at least 15-20 seconds before putting it into R
regarding @superswiss post earlier, the adaptations...thats an interesting take. I always put my car in P before turning it off, but I didnt consider that turning it off in S+ would have a difference vs C
Old Apr 17, 2025 | 09:26 AM
carzaddict's Avatar
update: let the car idle down and put it into reverse, the jolt was non-existant. will keep testing
will also try putting the car in C before turning it off
Old Apr 17, 2025 | 12:38 PM
W205C43PFL's Avatar
That answers it
Old Apr 17, 2025 | 07:20 PM
Jimmy_c63s's Avatar
Nice work man. Now don't forget it's good practice to reset the transmission every few months. And when it's due for a transmission service you'll find it better to drive once it's done 👍
