C63/C63S AMG
aynbody have done catless downpipe in NJ?
Old Mar 20, 2026 | 06:43 PM
kcxbaek's Avatar
2019 c63 cabriolet
just curious how you take care of the inspections.
Old Mar 21, 2026 | 07:53 AM
Sazabi's Avatar
2019 C63s
Don’t goto the state inspection stations, don’t have any lights on the dash, goto trusted shop that can do inspections.
Old Mar 21, 2026 | 09:01 AM
streborx's Avatar
Top Answer: 1
G550
Colorado's high density front range counties conduct mandatory emissions inspections at state operated facilities and at mobile road-side test sites while vehicles drive by. How do you avoid these surprise inspections?
Old Mar 21, 2026 | 10:26 AM
Sazabi's Avatar
2019 C63s
Don’t live in Colorado.
Old Mar 21, 2026 | 11:22 AM
kcxbaek's Avatar
2019 c63 cabriolet
my mechanic who does insepction said, even after tune it may triggers “not ready” sign. dont know what that is, have you experience anything like that?
Old Mar 21, 2026 | 11:30 AM
streborx's Avatar
Top Answer: 1
G550
I think New Jersey uses the same roadside systems.
Old Mar 21, 2026 | 11:31 AM
streborx's Avatar
Top Answer: 1
G550
Aren't indy mechanics who do emissions inspections licensed by the state?
Old Mar 21, 2026 | 11:48 AM
Sazabi's Avatar
2019 C63s
You’ll probably have to remove the tune, and drive very carefully e.g. no boost for 50 miles, and all your readiness monitors should be green. I’m running O2 spacers which also make things easier.
I’ve never seen them in my 7 years of being in NJ. So either I’m lucky or it doesn’t exist in NJ.
Old Mar 21, 2026 | 01:17 PM
kcxbaek's Avatar
2019 c63 cabriolet
[QUOTE=Sazabi;9274203]You’ll probably have to remove the tune, and drive very carefully e.g. no boost for 50 miles, and all your readiness monitors should be green. I’m running O2 spacers which also make things easier.
if i tune and install spacers also, that would solve the problem?
Old Mar 24, 2026 | 02:31 PM
CclassyKev's Avatar
2016 c63s sedan
Spark plug non foulers by Dorman from autozone where the upper 02 sensors go and mine hasn't thrown a code for it at all and passes testing.
Old Mar 24, 2026 | 08:23 PM
HLG600's Avatar
2009 SL63 AMG
It doesn't.
Been driving in NJ for 20+ years. Have yet to encounter anything like this.
Decades ago emissions were measured at the exhaust tip, but NJ moved away from that practice.
To pass inspection, it's an OBD2 verification that all emissions readiness monitors are active and a visual inspection for catalytic converters.
