CL-Class (W215) 2000-2006: CL 500, CL 600
2004 Maintenance
Old Oct 7, 2006 | 07:42 AM
WIldcat465's Avatar
2007 CL600
2004 Maintenance
What services are covered by the 2004 full maintenance program. Is it like BMW where wear items (e.g., brakes) are covered or is it just oil changes?
Old Oct 7, 2006 | 09:43 AM
Jud Chapin's Avatar
'16 S550 Coupe, '11 Lexus LS460, '02 CL500 (SOLD)
I had my '02 "b" service done and, in addition to changing the oil and filter, they flushed the brake fluid and coolant, replaced the wipers, and supposedly took a look around for potential problems. Call your dealer and they'll advise you.
Old Oct 8, 2006 | 08:33 PM
WIldcat465's Avatar
2007 CL600
The car is at the dealer. This is not a B service, just brakes. When my brakes were replaced the first time becuase they were worn, the delaer replaced them for free and now they're charging. I was under the impression that for 2004 and earlier, wear an tear items are covered. Am I mistaken?
Old Oct 9, 2006 | 12:26 AM
Jud Chapin's Avatar
Ask for a copy of the agreement from the dealer if you don't have it in your paperwork. Out of curiousity, how many miles are you getting out of your pads? I have over 26K on my original front pads.
Old Oct 10, 2006 | 08:41 AM
WIldcat465's Avatar
2007 CL600
This is the second time the pads were changed. The pads were first replaced around 23k miles. Car now has just under 41k miles.
Old Oct 10, 2006 | 10:28 AM
Jud Chapin's Avatar
Where is most of your driving done, city or highway. I've got about 26K on my '02 CL and the pads have never been changed. By far most of my driving is highway but I'd better check them to be sure. Just thinking more about this, though, I bought the car thru a dealer and it was Starmarked. I understand that when a car is Starmarked, they generally replace the pads. Well see. Have you replaced the rear pads yet?
Old Oct 11, 2006 | 09:17 AM
WIldcat465's Avatar
2007 CL600
Most of the my driving is easy freeway miles (i.e., not a lot of stop and go traffic). Car has had an easy life of plodding around San Diego.
Old Oct 11, 2006 | 10:17 AM
Jud Chapin's Avatar
Thanks for the info, WIldcat!
Old Oct 11, 2006 | 04:15 PM
BenzinoCLK500's Avatar
2001 CL 600 | 2004 Lincoln Aviator
wildcat if you dont mind, how much are they charging you? I need my fronts replaced. Did you just do fronts, or rears also?
Old Oct 12, 2006 | 04:55 AM
mjr24's Avatar
M6 Gran Coupe
What did you find out? Are the brakes free?
Old Oct 12, 2006 | 12:16 PM
bltserv's Avatar
2005 SL55, 2000 CL500
CL500 Brakes
I drive mine 50% Freeway and 50% City.
Replaced at 25K and again at 50K.
From other CL drivers I have talked to.
Thats about normal. Remember how much this car weighs.
Its a tank. Its going to burn through pads and tires at about the same
rate.
Pad`s and Labor all the way around should run about $ 370.00 Dealer.
Old Oct 12, 2006 | 12:26 PM
AdamG@NorCal's Avatar
EVOTECH Mercedes AMG
Please guys, before going into the dealer for any maintanence, its good to call the service advisor and give your VIN number to him/her. Ask him/her if you have a service/maintanence contract. He/she will inform you over the phone. I can help you guys check too. (VIN required.)
