CL-Class (W215) 2000-2006: CL 500, CL 600
what is this fluid under my car....??
Old Oct 9, 2006 | 08:55 PM
Wehrmacht_benz's Avatar
2001,CL 500
apparently when i park and come back there is some liquid on the pavement under my car...it is almost like water mixed in with oil (not from ac)...the car operates fine and no messages come up...what can this be? is this normal for the car to sort of drop a little fluid after you use it or should i bring it in to the shop...?
Old Oct 9, 2006 | 11:23 PM
OC kid's Avatar
ex 03 W215 now 08 e92 M3
Not supposed to leak
Bring it in Blahzayblah.
Old Oct 10, 2006 | 09:50 AM
phat-ho's Avatar
2003 CL500
blahz, could it be a suspension leak (ABC pump)? i know that our cars cannot sense this until a lot of it leaks out. more importantly, where are the car wash honeys? they never came by on saturday..
Old Oct 10, 2006 | 01:05 PM
2001,CL 500
haha ok...well
theres a huge dry puddle in my garage as if this stuff has been leaking ever since i got the car and then drying up before i see it...
i think a message would come up or id notice a ride difference but ill bring it in to someone...god damn this leak..
its coming from under the front part of the hood on the passenger side..is that where the abc fluid is?? my pump was replaced in january..
Old Oct 10, 2006 | 02:06 PM
Hal H's Avatar
2001 CLK320
I wonder if what you're seeing is the water that is condensate from the A/C system.
If this was oil, it wouldn't dry up. There would still be a puddle remaining on a (presumed to be) concrete garage floor. The ABC system uses a special hydraulic oil, so it would probably remain on the floor w/o drying up.
Even on a cooler day, I notice my car will produce water condensing from the A/C when I park it, or even in the driveway when I pull up waiting for the garage door to open.
I usually leave my A/C on automatic @ 72*, so most of the while driving during daytime, the compressor turns on. It seems that MB cars do condense quite a bit, compared to my older car's R-12 A/C system.
Since the mid-90's cars use R-134a refrigerant and larger A/C evaporators and condensers to overcome the lower BTU output of this newer refrigerant.
Old Oct 10, 2006 | 02:46 PM
phat-ho's Avatar
2003 CL500
umm..yeah, what he said.
Old Oct 10, 2006 | 06:13 PM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
Originally Posted by blahzayblah
haha ok...well
I'd bet your windshield washer fluid is leaking around the tubes to the headlights. Check the hose connection where it meets the back underside of the headlight.
Old Oct 10, 2006 | 09:00 PM
2001,CL 500
i often thought my windshield washer tank was leaking but mercedes have told me it wasnt....would that look like oil in the leak though> or maybe dirt mixed into the water at least because its not clear liquid..
Old Oct 16, 2006 | 10:53 PM
sped's Avatar
2008 GMC Sierra
Taste it........
Old Oct 17, 2006 | 09:46 AM
phat-ho's Avatar
2003 CL500
what should it taste like? i mean, bitter i would imagine...like old school cough syrup. aha-ha-hah-hah-ha.
Old Oct 17, 2006 | 11:33 AM
2001,CL 500
turns out a leak from the steering column...needed a little part but mercedes only sells the larger part holding the little part...600 dollars..
Old Oct 26, 2011 | 06:09 PM
roswellman's Avatar
2004 CL600, 2006 ML500
Can you tell me the name of teh part from the steering column I think I have exactly the same problem
Old Oct 26, 2011 | 07:16 PM
danlnyc's Avatar
04 CL55 (sold), 2012 CLS550 (sold), 2014 S550 (sold), 2015 ES300H (DAILY)
It seems like the OP is banned....and you revived a 5 year old thread
