CL-Class (W215) 2000-2006: CL 500, CL 600
Rodor Replacement
Old Apr 3, 2009 | 12:13 AM
Bo CL500's Avatar
CL500
Rodor Replacement
Can someone tell me how to replace the rotors? Thanks
Old Apr 3, 2009 | 10:49 AM
Jud Chapin's Avatar
'16 S550 Coupe, '11 Lexus LS460, '02 CL500 (SOLD)
Originally Posted by Bo CL500
Can someone tell me how to replace the rodors? Thanks
Are you referring to brake rotors?
Old Apr 3, 2009 | 11:24 AM
Bo CL500's Avatar
CL500
Yeah I am, as you can tell spelling isn't one of my strenghts.
Old Apr 3, 2009 | 01:01 PM
wease206's Avatar
W215/X164/C124
take the wheel off
use a little shape like pin size of a toothpick
and knock out the pin and slid out the pad
then after use a 18mm socket and removed the pad housing
use a zip tie and hang it somewhere
after that use a allen wrench and removed the little nut
that hold the rotors spray some wd40 and rotor are out
your done
make sure you have a 12 pk beer
Old Apr 3, 2009 | 02:04 PM
Bo CL500's Avatar
CL500
Originally Posted by wease206
take the wheel off
your done
"use a 18mm socket and removed the pad housing" This is what I have a problem with and need some more instructions on, which bolts do I unscrew exactly. you have any pics?
Old Apr 3, 2009 | 02:44 PM
wease206's Avatar
W215/X164/C124
i dont have a pictre not right now
here listen to this
you know where the pad housing is located right floow the metal
bar and you will see the 18mm there should be 2 one top and one on bottom
Old Apr 3, 2009 | 02:51 PM
Bo CL500's Avatar
CL500
here listen to this
so there are only 2 nuts? correct
Old Apr 3, 2009 | 03:05 PM
wease206's Avatar
W215/X164/C124
correct
Old Apr 3, 2009 | 04:54 PM
Bo CL500's Avatar
CL500
correct
thanks
Old Apr 3, 2009 | 07:05 PM
Oxygen's Avatar
W220 S65 AMG
Pad housing? They are called calipers.
Old Apr 3, 2009 | 07:51 PM
Bo CL500's Avatar
CL500
lol, its ok, i got the idea
