w215 stuck in P,plz help how do i dismassemble center console etc.???
If anyone has a step by step guide on the whole procedure it would be great!!
Any help is appreciated!, does anyone know if i hammer the top of the gear lever in order to get it out of P temporary will i still be able to just remove the plastic piece to make the fix, or will i brake the whole thing if i hammer it out of P????
I have read a lot on the subject but find it hard to find exactly the info i need on my w215 model, also im confused if i need to go under the car to detacha cable from the ignition???
Anyone here who has completed this entire procedure on a w215???
Tommy Axen
Can i just pull the carpet "away" to get to the screws???
Do you know how to disassemble the gear lever box to get the plastic piece out so i can get it out of p????
have you done this???
Thanks for your help.
Tommy
yes just pull the carpet away to get to the screws, if u are having problems taking the carpet out, then take all the other screws out and that will loosen the center concol and will be easier to take out the carpet.
i dont know how to disassemble the gear box.
i have taken out the center consel, but not the gear box
Tommy
Tommy
http://www.detali.ru/cat/oem_mb0.asp?TP=1
good luck
this is a common problem with these models.
Tommy
Here is a detailed instruction, you DONT need togo under the car, atleast not on the w215 model,
http://www.benzworld.org/forums/w220...ml#post3577201
Tommy
Tommy
