CL-Class (W215) 2000-2006: CL 500, CL 600
07- CL 600 V-12 Gear Shift STuck in Park!! HELPPPPP!!!!
Old Dec 22, 2010 | 04:25 PM
mzjay2's Avatar
ML 320
I changed battery on 2007 - CL 600 V12 and now the car starts but will not shift out of park......code reads "visit workshop without shifting gears" . Can anyone help??
Old Dec 22, 2010 | 05:30 PM
saintz's Avatar
GL450
Do your brake lights work? I'm not familiar with that code, but a bad brake switch is a common Benz issue, which prevents you from switching out of park.
Old Dec 22, 2010 | 09:06 PM
mzjay2's Avatar
ML 320
Where is battery in '07 CL 600 V-12??
Where is the other battery located in 07 - CL 600?? I replaced the battery and now I cant switch the car out of park.
Old Dec 22, 2010 | 09:07 PM
mzjay2's Avatar
ML 320
Btw- the brake light is working.
Old Dec 22, 2010 | 09:21 PM
Malibuguy's Avatar
CL 500
A common cause for not being able to
Shift out of park is due to a common flaw of the park lock .
Both my fathers S class and my CL had this failure.
We just had to have the cars towed and then repaired (expensive) at the dealer.
Very common problem which Mercedes has known about
for years.
Old Dec 23, 2010 | 12:22 PM
biker349's Avatar
cl600
i've read that if you simultaneously pull the shifter back while hitting the top of it and keeping the brake on it may come out of park. there is a super long thread on this recently. check it out and let me now if i'm right.
Old Dec 23, 2010 | 10:35 PM
truncalep's Avatar
Cl 500
I believe theres a pin underneath the shifter that can shear from wear and will not allow you to get it out of park. Youll have to tow it to the dealer and they will take the shifter apart and replace the pin to align it again.
Old Dec 23, 2010 | 10:54 PM
bzliteyear's Avatar
07 E63 06 CLK55 Cab 03 P-car C4S
i had this happen to my 2000 W210 E320 wagon - sometimes it would get stuck in Park...had to play w/ it or wait 10-30 minutes. Finally the dealer changed some major parts. Thank goodness for CPO warranty.
PL
Old Dec 24, 2010 | 08:30 AM
Jud Chapin's Avatar
'16 S550 Coupe, '11 Lexus LS460, '02 CL500 (SOLD)
There are many posts on the subject so do a search. You can start with this one:
https://mbworld.org/forums/s-class-w...k-problem.html
Old Dec 24, 2010 | 10:44 AM
biker349's Avatar
cl600
great job jud, i was going to recomend that.
