CL-Class (W215) 2000-2006: CL 500, CL 600
HELP- KEY WONT WORK IN CL500
Old Dec 4, 2011 | 03:21 PM
cool aide's Avatar
CL500
GOT IN MY CAR - STARTED ENGINE-- WILL NOT SHIFT-- SAME KEY I USE EVERY DAY -- HELP
2000 CL500
Old Dec 4, 2011 | 03:57 PM
STNTONU 510's Avatar
W215
Step on the brake lights and see if they come on...if not then it can be a fuse like mines
Old Dec 4, 2011 | 06:08 PM
cool aide's Avatar
CL500
YES THEY COME ON- SPARE KEY DOING THE SAME THING
WHAT IS THE SOLUTION ???
BESIDES THE DREADED DEALER
Old Dec 4, 2011 | 09:06 PM
nlieber's Avatar
cl500 2001
There is a common problem with the reverse lockout arm braking (it's plastic). There are several posts addressing the issue on this forum and on Benzworld. Replacement part avail on ebay for under 100.00
Old Dec 5, 2011 | 03:00 AM
cool aide's Avatar
CL500
HELP
sorry--- BRAKE LIGHTS COME ON WITH IGNITION OFF-- KEY OPENS DOORS AND TRUNK BUT WILL NOT TURN IN THE IGNITION--
Old Dec 5, 2011 | 09:37 AM
nlieber's Avatar
cl500 2001
Your first post said you started engine and couldn't shift. Later post says key won't turn in ignition? Your vehicle has keyless go?
Old Dec 5, 2011 | 10:35 AM
cool aide's Avatar
CL500
i am experiancing both problems- first it would start but not go into gear-- now ignition will not turn
however- remote does open up doors and trunk
looks like im taking the bus to work????
Old Dec 8, 2011 | 05:47 PM
nlieber's Avatar
cl500 2001
So any update on this problem?
